I tried to pry up the hour, minute and seconds hands from the dial but they seem quite stuck and dry due to not being serviced for decades i presume. How do I take the hands off without the risk of bending the dial?
The hands are fitted without oil, so they should be dry 😉.
Use wide hand levers. They give more control and the load is spread more to avoid damaging the dial.
6 hours ago, HectorLooi said:
Put a tiny drop of 9010 on the hands and try lifting just one hand at a time.
Are you using hand levers or Presto tool?
Im using hand levers so maybe a bit tricky to take one by one
