Hello all.  I'm working with an ETA 963.116 quartz movement.  The movement original to the watch was not working so I changed the battery and still no luck.  I used the Horotec turbo to possibly free up some old oil or dirt that might be in the gear train but still no luck.  The train was free and the hand did move when the tester was activated.  So I sourced what was said to be an NOS movement, but when I installed the battery, the gear train pulses but only advances every now and then.  I decided to disassemble the movement and clean it being it was quite old and hadn't run in quite some time.  After re assembly the same is happening, pulsing but the wheels don't advance.  I removed the rotor to check the gear train and it spins nice and free.  I then installed just the rotor and watched its operation.  This is where I'm not so sure what is normal.  The rotor pulses every second and rotates 180 degrees.  Is 180 normal or should it be 360?  As soon as I add the next wheel its back to pulsing and does not rotate the wheel.  Any advice would be appreciated.
17 hours ago, Stevelp said:
clean it
What would be her definition of cleaning and did you lubricate it?
NOS movement
The problem with the new old stock movement is this is a really old movements. Approximately 43 years old to be as a guess based on the tech sheet.
It's supposed to rotate 180°. Then it definitely should rotate the next wheel that can't rotate that it can't rotate the rest of the watch.
One of the problems with electric watches is there's integrated circuit and  electronic things like a coil it be nice to test things with test equipment.
Thanks everyone for the responses!  As far as cleaning, I have an L&R varimatic that I use with the appropriate L&R fluids for cleaning watches.  I lubricated the pivots with Moebius 9010, being careful not to overdue it as I have read quartz watches can be fussy with to much oil.  The rotor was cleaned with rodico and not put through the cleaner.  I appreciate the link for the tech sheet watchweasol.  Can those rest points be checked with a standard multimeter?  I don’t have any quartz testing equipment (though after this I might think about it.)
Yes the voltages can be tested with a multimeter but if the rotor pulses I would expect the fault to be mechanical.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
