On 11/8/2024 at 10:00 AM, HectorLooi said:
High quality Chinese made watch automatic cleaning machine for watchmakers to clean watch parts
https://a.aliexpress.com/_mtEsap2
They did. But they cloned the high end machines. My mentor has one of these. Every parameter can be programmed but the instructions and LCD display is all in Chinese. I'm not sure if the default language can be changed.
it looks like word of the Chinese machine has spread to cousins as they have one for sale. Also early English or two separate English manuals are available and a video.
Visually the machine looks beautiful video is interesting I would be curious about exactly how the ultrasonic works as it's a bit vague. Along with apparently things can be programmed for the ultrasonic but even the manual although I was really excited when I saw it and didn't have time to read the fine print so maybe it's in the fine print like the various frequencies etc. But no matter what the price totally beats out everybody else if you want a fully automatic machine.
https://www.cousinsuk.com/product/biao-jiang-watch-cleaning-machine
ÂŁ2500 and you have to fit the door knob !!
That is to give you the sense of accomplishment that you had a part in the build of the machine.
  • Haha 2
It's probably why the machine is so much cheaper than the Swiss were the knob is already attached. In other words it's a cost savings feature.
  • Haha 2
    • Hi guys. @VWatchie Those images are self hosted (not hosted on this server). Do a look at the page source and you will see this. I’m afraid, I can’t have control or backup images not hosted on this server. This server is backed up fully every night and the database is backed up and versioned every hour, all stored off site on Amazon S1 platform. It’s hard for us to lose data. Ive got a huge overhead of space on this particular server the site is served from so no worries there 🙂 Sorry all for lack of response so far, I have been extremely busy and am embarrassed to say that priorities had to be set in place for a while.  Be assured that i’ve got constant monitoring and alerts should the site be in an extended problematic state (down etc) and work on these issues if they arise.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
