Where to get ELMA cleaning machine restoration help?
2 hours ago, Bigjay said:
I think i’m definitely going to get it all taken out and find someone to rewire it for me.  I can cope with the cosmetics but the electrics im not willing to risk!! I’m so desperate to have a working machine… i love this hobby!
Where in the UK are you?
I find this discussion rather confusing, esp. for the OP.
Imo his picture of the wires coming from the machine correspond exactly with the posted schematic. I can see nothing wrong on wiring of the machine side.
Just the kind of connecting those to the extension cable is questionable, anything but pro, but would be functional (assuming both red wires are protective earth).
I would just replace plug with cable where protective ground is yellow/green and use proper connecting terminals, proper strain relief.
Frank
Frank
That maybe sufficient to test the operation of the machine but due to lack of earthing and unknown condition of
the insulation along with the individual cores to the motor a rewire would be the only way to ensure safe use.
If it is to be powered up then it needs to be on a variac with current monitoring to slowly increase the voltage.
Edit
Also before power is put anywhere near it the heater, motor and rheostat should be checked for any shorts.
Edited by AndyGSi
37 minutes ago, praezis said:
Andy, where do you see a lack of earthing? I don‘t.
Frank
Looking at others the only earth appears to the top of the rheostat so the base, control housing
and motor cover are all relying on bolts and touch contact for earthing which isn't adequate.
The earth to the rheostat doesn't even appear to be their on the OPs.
Edit
The above photo is a clip from the YouTube video.
Edited by AndyGSi
I couldn't find a small appliance electrician when I was looking at my wiring (Devon, U.K.) so I just put it back as it was. I didn't do a rewire as such, I simply removed the wiring in order to clean the machine. But my issue was that the motor had an earth wire going to it which was deliberately cut off at the motor end. Someone saw a post of mine on Facebook and we swapped notes, as he was doing the same. It appears that there is no earth going to the motor, so I'm guessing that the person who rewired mine (it had UK colour coded wiring) didn't have any two core wire and simply used the three core but cut the earth off!  Mine is working fully now, so it seems that I got it right!
Happy that it's working but getting it right and it being safe are different things.
Each metal part should have its own earth as currently if there's a short at the motor for
example and the case becomes live the only path to earth would be you when you touch it.
Hi all, back again with a few questions…. I am back on re: trying to figure out the rewiring of this Elma super elite machine. @AndyGSi provided a wiring diagram and quite rightly pointed out that my machine did not have an earth to the rheostat like some others.  You may remember the photos of the dodgy extension of the power cable from 4 core to 3 core and I have since discovered that the previous owner had marked the grey wire as the ‘earth’ with a little sticker!! In the provided wiring diagram the grey wire is marked neutral and I seem to remember someone commenting that in the original german wiring, the red wire was the earth!! Now im starting to think that my machine MAY be wired up completely incorrectly and that the way forward is to ignore the existing wiring and start again with completely new wiring and follow the diagram??  Does anyone think this is a bad idea?  If not, should I buy new 4 core cable and follow the diagram or use the normal 3 core UK standard cable??
Secondly, where would the experts here connect the earth as the wiring diagram does not make that clear.
If someone was minded to draw me an even easier to follow idiots diagram with more detail, then I would be eternally grateful!!
I think i would be minded to replace the switches and replace the bulb for an led one.  The heater plate, I can replace with a modern direct replacement from HS Walsh too.
Your advice and guidance is greatly appreciated!! 😬
My suggestion would be to rewire from scratch.
You're best just using 3 core mains flex and then use this type of connector in the base.
https://www.amazon.co.uk/lever-splice-connector-221-413-terminal/dp/B0744BG6FR?crid=Z9OCYHATWX61&dib=eyJ2IjoiMSJ9.li-z2OlSrWEmL8WFRdSZWq51-SCkLY1U3s5NZfnMDRJPeu9A7tKHPvNBLEID1ZzWlHlkf-tqangnjIfvxKs3tg4u0ayjqdLJce2-_eKE87GzWqSZBvPe6a1TkuiZ9PqW41Fqk6hKZ8NazXdPw776_9iFPBTvXo68wo10yPOu9fzElkfEoKnwLOEqGhTK9QvAID8sD_d8lmFld2XZ2Tc5rJapCJUP9T6d3jtADR5YigtvLjd3Uvyf1jkkdYbIPTCPtuJ5VoQjtPuvoNl-ceUS3HcIYX-ATiSEd8BjjvRFkm0.pvOGRr6_3pv6r-zhPl_EwgntlIkZIye-e2egc4UWHQw&dib_tag=se&keywords=wago+connectors&nsdOptOutParam=true&qid=1733241483&sprefix=wago+connectors%2Caps%2C119&sr=8-7
I'll see if I can knock up a bit of a sketch but not sure where you'll be able to connect the earths?
To others that are looking at this and wondering if its worth the effort, only you can answer that question. But, I have written some basic code to build one of these machines, for fairly cheap, with a stepper motor, driver, and an arduino. Whole thing can be built for around $100-150. I can start a new thread if interested. The plus side, is it can be expanded and updated to whatever you might like it to do. Right now, I have it set up to have 3 buttons, one for starting the cleaning, one for a spin cycle, and one for a drying cycle. I am working on adding a linear Z-axis, so that the cleaning and spinning are automated. Eventually, ill have a turntable axis as well, so all the cycles can be completed with the push of 1 button.
5 hours ago, AndyGSi said:
Thanks Andy, any help would be appreciated.  I can always upload some photos as I progress if you dont mind checking that it is consistent with what you think the wiring should look like.  And i’ll be sure to photograph everything before I remove it just for interest if nothing else!  Cheers Jason.
I definitely think its worth the effort to try keeping these vintage machines going but i’d be interested to see your project too.
22 hours ago, tomh207 said:
@SwissSeiko that sounds really interesting, would love to see the design and it working
Last night I spent some time making additional code to add the linear Z axis. So far it appears to be working(simulated) well. I've also eliminated 2 of the buttons, and automated the entire cleaning and spinning cycle. I've no way to simulated a drying step in the form of a heater and fan on the software I'm using, so that will need to be done once I order the parts. Once I finalize everything in the code, like adding a limit switch for the Z axis, ill order the parts, complete the build, and post it here. So far, I'm at around $120USD for the build, without frame, but with the Z axis. Removing the Z axis, the cost is around $70USD without the frame. This does not include jars or basket costs though.
Edited by SwissSeiko
19 hours ago, AndyGSi said:
That is fantastic!! Thanks so much Andy!! You legend! Regards Jason!
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
