Hi All,
I wonder if anyone might be able to help me identify the markings on the back of this west end watches...watch, please.
SIS?
Y 6600?
I've as yet been unable to find anything online that matches.
Thanks in advance
Matt
Thanks guys, that enabled me to narrow down the search! I've found markings that look similar (although the arrow tends to go through the middle of the SSs on others ive seen), so that looks to be along the right track.
I'll pop the case open shortly and will report back.
Thanks again
Edited by MattWatch
Spelling
11 hours ago, JohnR725 said:
Usually any time I see the arrow symbol on A British watch I do think of army as I think it's their symbol.
Known as The Broad Arrow or Pheon....originally used to mark British Government ownership....later adopted by the British army. I think its no longer used ....🤔 actually illegal to use it without permission.
12 hours ago, MattWatch said:
Hi All,
SIS?
Y 6600?
Thanks in advance
Matt
🤔 A British field agents watch.....one great way to give away your identity as a spy 🤣
Not something our " James " would wear. " Do you expect me to talk "......." Nooo Mr.Bond I expect you to die "
Hell yeah I'd talk if i was strapped down to a table with a laser heading towards my nuts 😂
Can we find out more about this symbol pleaseee ?
It's West End Watch Company
Ah thanks Andy, i couldn't make out the W with my wonky eyes, tapped the side of head with my fist and they fell back into position.....now i can see the W matey ...thank you 👍.
7 hours ago, nevenbekriev said:
The 59s were used in both the www and atp Brithish military watches
19 hours ago, AndyGSi said:
Strange how the outside number doesn't match the inside number and there's nothing on the movement cover.
Looks to me like some doctoring has taken place.
Perhaps the ref on the case back is a military ref and the one on the inside is the serial number of the watch no?
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
