Hiya everyone,
I was wondering about buying one of those rubber balls to remove screwed on case backs. Are they any good? They seem like a good idea to me but I'm a novice. They range in price on amazon for £3-£20ish. I wondered are the more expensive ones worth the extra money?
Many thanks in advance.
Ruffass
I have a cheap one that was around £3 iirc and it works fine. I have seen around folk using balls much cheaper than that and not a watchmaker tool. At the end of the day it’s just a rubber ball to give you some friction onto the caseback and easy to grip in your hand.
Tom
The balls are great, they work most of the time (80%??) and are guaranteed not to scratch or slip. I think the balls are all pretty much the same.
I have the same verdict. 80% of the time it works and there's probably no significant difference between them.
I think it's an essential tool to have. Go for it.
They work in many cases for removal and then are also an easy way to get a pretty firm tightening when replacing a back. They do pick up dust and finger oil which reduces the “sticktion” so clean them with dishwashing soap as needed, keep them in a plastic bag for storage and handle them in a way to keep them clean.
I agree with most of what has already been said. If you don't already have it, I recommend buying a cheap ball pump as the ball tends to deflate after a longer period.
As for the brand, it probably doesn't matter much, but why not a ball from Bergeon? You can enjoy the feeling of operating with a genuine watch tool 😉
As far as efficiency goes, I would say that most case backs can be unscrewed with this type of ball. As someone else mentioned, you may need to start with a more powerful tool. Preferably a clone of the Bergeons. Google "Vevor watch case back remover tool".
I actually get a bit upset if I don't manage to open a case back with my rubber ball. Upset because there's no reason whatsoever to tighten a case back so much that it can't be opened with a rubber ball. I never use anything other than a rubber ball to tighten a case back, but of course, I then tighten it as hard as I can.
I reviewed the Bergeon 8008 ball on YouTube a few years ago.
Regarding the less expensive (non-Bergeon) balls...
I have an unbranded ball I probably bought from Esslinger when starting out. I believe it is 10-15mm smaller in diameter than the Bergeon 8008 and I do think that makes a difference. There are some casebacks I cannot get good purchase against even though they are not tightly screwed down. So if others are saying 80% success, I would put my cheaper one at only about 65%. Get the 8008 (or figure out its size and buy a generic one that size).
I have not spent the $10 to upgrade my inferior ball because I don't actually work on many screwback cases. It's mainly snap cases or the 2 piece screw down ring on older Russian watches.
Tom
Cheers Tom 👍
Thanks Waggy 👍
10 hours ago, AndyGSi said:
I had one but found it useless when trying to release the back and only any good once I'd used a proper tool first.
Cheers for the advice Andy 👍
Thanks Knebo 👍
Sounds good advice Geotex, Thanks. 👍
Thanks for the advice Vwatchie. I'll have a look at Vid in a bit. 👍
Thanks Mbwatch, much appreciated. 👍
Cheers Richard,
I've seen cheap Burgeon Chinese copies on Ali express that to me look Identical. Only fair to assume these have made their way onto Ebay/Amazon UK.
Cause of this and the fact that Black doesn't show the dirt as good I've just gone for a Cheap Blue one.
Screenshot_20241115-062802.thumb.png.86b143b59f78b37735fc4c6c4017c349.pngAs a matter of fact I got that and a £30 pile of other cheap chinese tools/accessories off of Temu Click and Collect. Can't go wrong! 😆
  • 4 weeks later...
I got a cheap non-name one of Amazon about a year ago and I use it all the time.  Unless a previous tinkerer did the unthinkable and overtightened the back it always works.
One tip I received was to slightly deflate the ball so it's not firm but slighly soft.   I was told it allows the ball more surface area contact on the case back, I thought the guy who told me was nutz but i tried it and my ball actually works better.    Does anybody else have any experience with this or am I now nutz too?  😉
Nope not nuts, sounds perfectly feasible.  Like letting some air out of car tyres in winter so they grip the roads better.
Maybe not just the amount of surface contact area, which can be increased to cover all of the caseback by pressing harder without deflating . But also a softening of the ball's material due to less air pressure inside it.
    • Hi guys. @VWatchie Those images are self hosted (not hosted on this server). Do a look at the page source and you will see this. I’m afraid, I can’t have control or backup images not hosted on this server. This server is backed up fully every night and the database is backed up and versioned every hour, all stored off site on Amazon S1 platform. It’s hard for us to lose data. Ive got a huge overhead of space on this particular server the site is served from so no worries there 🙂 Sorry all for lack of response so far, I have been extremely busy and am embarrassed to say that priorities had to be set in place for a while.  Be assured that i’ve got constant monitoring and alerts should the site be in an extended problematic state (down etc) and work on these issues if they arise.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
