Rolex Cameror Cuss & Co Pocket Watch
Which jewel is it you're looking for so we can advise if you just have to get a generic one or a specific one.
I'd just use a standard case back hand tool with either some Kapton tape or the silicone paper from the back of a label as protection.
By watchweasol · Posted
The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools -
I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
It's an exhibition back so no access as you suggest.
