Storing cleaning fluids, specifically Elma jars
Hello all,
I wonder how you all store your cleaning fluids, particularly the "professional", expensive, waterless ones. I heard that they can evaporate quickly or "go bad". And since I only use them once every 1-3 months, I want to make sure I'm not wasting them.
As many of you have seen in other threads, I just got myself an Elma Super Elite and ordered fresh cork gaskets for the Elma jars. Do the waterless fluids store well in there?
Or is it better to put them in special storage containers between uses. If so, which containers do you use?
I also saw these alternative gaskets for the Elma jars, made of polyurethane. According to the seller, they are "significantly more durable and tear-resistant than conventional cork gaskets and ensure improved sealing of the jars". https://watchparts24.de/Three-pcs-gasket-set-MADE-IN-GERMANY-for-ELMA-Super-Elite-watch-cleaning-machine
What do you think?
Cheers,
C
I suppose it will depend upon a variety of factors like the containers they come in. Then whatever containers like the cleaning machine jars which have a lot of open space and surface area for evaporation plus the temperature that it stored at
so at home when I used to clean watches I was using L&R cleaning fluid and rinse. I was using the method where you have a beaker and an ultrasonic tank and then I would use some plastic 8 ounce containers wide put about 6 ounces of fluid in each. Then from time to time when they were dirty I would change out one of the rinses and the cleaner. So the first gallon of cleaner that I had lasted for my really don't remember how old but will say more than 10 years by quite a bit. What I noticed was eventually the cleaner just wasn't cleaning but as far as I can tell the rinse other than conceivably evaporating doesn't break down at all
then I just now checked the replacement cleaning fluids the rinse still looks fine and yes I really shouldn't put dates on these things. The cleaning fluid probably half a gallon left or more still looks the right color but definitely had zero ammonia smell. No idea if it would cleaner not if I need to clean a watch I just take it to work where we ever really nice cleaning machine.
then the 8 ounce plastic containers apparently I never emptied those out at all and they eventually evaporated and the plastic lids themselves cracked rendering them unusable. But who knows when the last time I cleaned the watch at home was
so my best guess is providing the containers they come in last forever and you never know with plastic the rinse probably would last almost forever. The cleaning product will eventually break down because David has ammonia that will go way. In the cleaning jars don't really know other than there is a lot of surface area. But I'm guessing even a couple of months isn't really going to be an issue. If you are really concerned you could pour out of the jars into some container with a volume close to the fluid level so you have less surface area for evaporation.
I use one litre Kilner jars with lock-down lids for larger quantities from clock cleaning, and jam jars for the small amounts I use in my ultrasonic cleaner.
I use cut-off plastic drink bottles as intermediate containers in that; I found some that the round mesh basket I use fits in perfectly, so a fairly small amount of cleaner and water around that.
I think the flexible plastic passes a lot more energy in to where its needed that using glass intermediate containers.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
