Hello,
I’m stuck with my 7S26 rotor screw, it just wont come loose and I dont want force it. I’ve heard that the usuall problem with these is that they tend to come loose on their own, but mine is stuck. Any suggestions on how to proceed?
3 minutes ago, Klassiker said:
If they tend to loosen on their own, might someone have glued it? Heat or solvents depending on the adhesive would help in that case.
It crossed my mind that somebody may have used glue or something… do you have any suggestions on what solvents to use?
3 minutes ago, AndyGSi said:
Welcome to the forum.
Which way are you trying to unscrew it and what screwdriver are you using?
Thanks!
Lefty loosy and I have just the right screwdriver for it but it just wont budge..
