Is it possible to repair a screw down crown?
The crown on this Mido 8299 screw down crown seems to be broken. When I turn the crown counterclockwise the stem turns with it. When I turn it clockwise the stem does not turn with the crown. This makes it impossible to set the time backwards or use the day (date? I forget) quickset. I've tried to find a NOS one but haven't had any luck yet. Is there any way to fix this?  I thought about maybe putting a thin shim between the crown and the stem but as the stem is spring loaded I don't think that would work.
Edited by GuyMontag
To be honest, I don't even know how the stem is supposed to come out of the crown. I assume it isn't screwed in as I don't see how it could be spring loaded if it was.
EDIT: just to test I put the stem in a pin vise and tried to remove the crown but it doesn't want to come off.
Edited by GuyMontag
I did try removing the stem with a pin vise and it doesn't want to come out. I didn't pull crazy hard. That video said that, at least in that style of screw down crown, it's glued in. Not sure if that is true, that sounds a little odd. I've seen other posts that say it's soldered in? If it's not held in mechanically and it is glue or solder, I'm worried that if I take it out I won't be able to get it back in again.
8 hours ago, AndyGSi said:
I expect the spring has lost it's tension and isn't pushing the crown out enough to engage with the stem.
To remove the crown try gripping the crown tube and then rotate it anti clockwise.
Marc...articulated guy with great knowledge......explains clearly enough to understand in a heatbeat what's happening. Worth watching his other tutorial videos and collaborations with Tristan Veneto.
Its the collet that is glued/soldered to the crown. Marc did say its a permanent assembly...so unless the keywayed collet is screwed onto the crown with yours . Maybe yours isn't a keyway that locks the stem both ways and operates as a oneway latch.
It's got to lock both ways if it's got Day & Date Quickset.
Did you try holding the crown tube instead of the stem and then unscrew the crown?
I was surprised that you can repair these. I had one on a Ladies Rolex/Tudor where the spring had broken inside. I managed to change the spring and get it working. You have to grasp the centre tube very tightly in the pin vice, BUT not crush it. Watch the video.
Edited by mikepilk
Thanks all. So I did as in the video and grabbed the crown by the tube with a pin vise and cranked it tight with two pliers. I tried to remove the crown but it wouldn't budge. I then heated the crown up with a soldering iron and it still wouldn't budge. I guess this is one of the soldered type and not a screw or glued type. Unless there is something else to try I guess I'll just have to wait and see if one turns up on ebay.
18 minutes ago, AndyGSi said:
If you pull the crown while holding the stem does it move our further and can you get it to lock in both directions?
Good call. I had tried that before using my fingers and it still wouldn't lock in CCW. I just tried putting my smallest screwdriver blade through the hole in the split stem and pulling on the stem and I heard it "pop" and it now locks in both directions. However, it doesn't want to (easily) push back in. I used a decent amount of force and it pushed in, but it stayed compressed. I pulled it back out and and still locks, but something is clearly borked with the spring. I think I may be able to use it as is until/if I can source a replacement. Cheers 🍻
Edited by GuyMontag
Try soaking it in IPA and see if you can get any debris to come out which maybe restricting its movement.
If you've got an ultrasonic tank then put it in a little bottle of IPA and leave it to soak before putting the bottle in the tank for 10 or 15 minutes.
Edited by AndyGSi
I'd use naphtha as IPA isn't good at dissolving oil and grease.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
