Hello everyone. I am servicing several models with the 613X caliber and have had some issues with the disassembly and reassembly of the Diashock system. My question is the following: are all Diashocks the same size? Can I take one from another caliber and use it here? It seems like an interesting option because there are aftermarket options at a much better price. I think I came across a page that indicates the compatibility of watch parts, but I can’t find it now. Do you know what I’m talking about? Thanks a lot!!!
I’ve never seen the list your talking about, but if you look at the part number your after on the service sheet for the movement , then check later movements for the same part number.
Hope this helps.
If you look in the service sheets they list the diashock part numbers e.g. for 6139A. Just check whether the numbers are the same for other movements. Unfortunately I don't see them listed in the Jules Borel database.
