Prior owners of my Marshall staking set were maybe not diligent about using brass hammers and most of my solid domed punches have mushroomed ends as pictured, so they don't fit down through the plate to invert. I have to push them up from underneath, inconveniently.
Is there any reason I should not just chuck these into a drill and take a file to the back ends, then clean up the evidence with fine sandpapers?
I have a couple of free days and plan to spend some time finally cleaning up my whole staking set.
PXL_20241128_015841276.thumb.jpg.a7917c3e560d9b9cda38f44c87e060a2.jpgPXL_20241128_015853441.thumb.jpg.82b7e07aca47480f9ea61b7470f44b62.jpg
Edited by mbwatch
title clarification
  • mbwatch changed the title to Filing or reducing spread punch ends?
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
