Staking tool?
That's a puller intended for pulling roller tables on balances.
Ahh of course it is. I have just noticed the small hole in the end of the centre (push) part for the pivot. Thanks you very much 👍
Edited by Burruz
Its for pulling watch hands off. The center piece which is adjustable presses on the top of the cannon pinion. The two side pieces fit under the hands and by turning the adjuster at the end it will pull the hands off. I had this very tool in my workshop.
I have half a dozen versions of this tool with different centers and have used them for pulling both rollers and hands. The one with the through hole with the adjacent hole i use for roller removing , the staff pivot can run through and if breaks can be cleared out.
Personally i prefer this for removing the roller table, the jaws need to be kept free of damage .
How do you go about maintaining yours? I have both the Indian copy of this tool and the real Bergeon/Bradux and every time I use either of them the blades get further chewed up.  I've used them on pocket watch roller tables. Eventually I bought good staking tool accessories for roller removal and have not gone back to this type.
Edited by mbwatch
The Indian one is naff, the Bradux one is better, its just a case of being really careful with them. The steel they are made from is not tough, I keep on top of any damage thats about it. The reason I like them is for the view and control I get with them.
Has the bergeon one got hardened blades?
I have 2 bradux which I seem to think is Bergeon. On both the jaws were a liitle chewed up when i got them in some joblots. No idea if they are hardened but maybe not as roller tables are soft, unless a heavy handed someone has been chopping balance staffs with then .
6 minutes ago, Burruz said:
I also got this little gem. I don’t know what it is but the older tools had so much more style.
Oooh that's a beauty. What a box too!
That is a balance poising tool. The two jaws have a hard substance (ruby ideally, sometimes agate, sometimes hard polished steel) which are intended to be perfectly parallel. The balance (without hairspring) is placed with pivots spanning the two jaws and allowed to gently roll. If it stops in the same place, that spot is heavy and needs to be compensated either by removing weight there (from a screw or boring a tiny divot) or adding weight to the opposite spot. Example:
1 hour ago, oldhippy said:
Having the little round level means its complete
That looks like a modern plastic replacement level as can be bought on amazon (exactly like the one I have mounted on my Bergeon/Vigor poising tool)
If they arent hardened, its east to do yourself. Just touch some part of the tool on a bench grinder and see if the sparks are bright yellow. Then you can harden it.
14 minutes ago, oldhippy said:
I didn't know you could buy modern replacements. I stand corrected.
They're cheap! But not great. Definitely not good as the heavy & stable old ones with metal bases. image.png.1136e296591e8fd73826eb3895083b48.png
28 minutes ago, Neverenoughwatches said:
👍big bright yella sparks...carbon steel.....little orange ones....hss.
Now I gotta buy a bench grinder too? There's no end to this.
The more you do, the more you need the tools to do it. Does it ever end ? Probably not in one lifetime 😄. Get a lathe...then you can make more and buy less.  Now I've found my lathe/lathes....as Caseback put it.....I'll never buy another jewel pusher....In fact I could have save a hundred notes on the concave pushers and hand closers 🤦‍♂️
23 hours ago, oldhippy said:
Having the little round level means its complete, I have seen so many where the level is missing. Look after it with care.
I will do thanks. It just looks and feels so well made. I understand it is German from around 1920's.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
