FEF 310-based project
Preamble: one of the things that brought me here was a walk-through for servicing an ETA 2836-2 that resides in a Hamilton Khaki King.  Everything went very smoothly, and i came away from the experience feeling a bit.... well, froggy.  I saw a listing recently for a Kreuter with a FEF 310.  Bought it and a donor movement.  This was a good call, because it felt like at every turn, there was an issue.  Original balance had a roller jewel floating around inside the case, no snap action on the pallet, ect ect ect.  As I have now had this movement apart several times now and have gone through nearly every part swap or change-a-round i could think of, the balance now sits stationary yet free to spin with a full wind.  The caseback has markings on it from the mid-1940s so feels like a shame to abandon it.
I'm at the point where I'd considering just taking the hit and taking the experience away from the project, or sourcing a functioning 310.  I'm not really at a place in my journey (tools, talent, and experience) where I can reasonably deal with a basketcase.  Hoping someone has some advice; do I put it down? Source a movement?  Thanks in advance.
My apologies, i didn't really doo a great job of stating my issue. I'm trying to figure out when it's time to keep pushing through an issue and when it's time to accept a loss and move on to another project.
The watch has actually started running and gained 4 minutes over 8 hours so I suppose it's not fair to call it a total loss, but still has issues I suspect are outside my skill set, at least for now.
Welcome to the forum matey. I  experienced this exact dilemma myself many times when i started and still do from time to time.  So my policy is to soldier on, and get the movement running to the best of my abilty at that time. This statement brings two thoughts to my mind: one, I dont realise what my ability is until I've soldiered on, and two, i have learnt so much more from having that attitude. The only things that would stop me in my tracks is lack of material or parts, which would  be rather surprising or requiring a specific tool, which again would be surprising.  Those two clauses generally develop from... me being as tight as a duck's arse 🤣
To extra clarify the surprising statement...geez god knows how much stock i have ! and geez god knows how many tools I now have ! And if i dont have the tool i would probably try to make it rather than buy it, which again stems from being as tight as....😄
So enough about why I do what I do, lets have you doing it. So whats the crack with your watch, what are you looking to fix ? The extra time over accuracy , is this just a required regulation adjustment or something more ?
Edited by Neverenoughwatches
I'm working with limited experience here, but my assumption is too little (maybe too much?) endshake on the balance shaft, which is beyond my skillset to adjust at least as of now. Honestly, accepting it for what it is and revisiting it at a later date is where I'll most likely end up heading.
Edited by holdorf333
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
