Measurements for Mosely/Marshall inverted punch receiver piece?
Since I've finally gotten to cleaning up and refurbishing my C&E Marshall / Mosely staking set, I hoped someone could take a couple measurements for me. My set is missing the tube which receives the bottom end of inverted punches. I have been using a makeshift piece with bolts and nuts in its place and it's time to try to fabricate something better. If you have one of these staking frames, could you measure the outer diameter of the tube and the diameter of whatever is underneath it and connecting it to the frame base?
I believe the 4.7mm hole is slightly eccentric. If you could estimate about how far off center, that would be great too. I imagine it can't be more than a few tenths of a mm. Finally, what is that piece made of? I would not expect hard steel.
I never did find out the size of that piece. I am in the process of assembling a lathe and my first order of business is to make that part (or some approximation) when my 3 jaw chuck comes in. If that does not work out, then yes I may ping you! Welcome to the forum.
I’ve got a few errands to run this morning, but when I get back I’ll grab you some measurements of one of these here. It’s takes just a second to pop them out of the base. I do have extras so if you want one I’ll send it to ya, but either way I’ll grab some measurements for you. I haven’t set up my re-plating station yet, but even then some of these anvils are so damaged that they wouldn’t be worth trying to plate, so I probably have 6-7 extras.
   The center hole is offset and the back side has a bevel ground into it where it touches the anvil front. I’m assuming this is to make sure you install it so the offset hole to catch the inverted stake is in the correct position.  I took some random photos to try and show the details. As long as you don’t have a little giant anvil it’s offset.  The little giant ones appear to be dead center.
This is so helpful thank you. It looks like I was misjudging that part's function. I assumed it was drilled eccentric so that it could be rotated for alignment like the knurled top piece works. But that bevel means it is fixed in one position.
I measured the horizontal position of the hole on the underside of the die plate where the punch comes through and am surprised to find it is not centered. It's about 1mm offset and I guess that bottom receiver compensates by being off center. What a weird design.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
