Omega 565 (and other Cal's) Date Disk Refurbishment
I have parts coming to finish off my Omega Seamaster 300 build, using a Cal.565
The 1 item I am not able to source is the Black date disc with white text. So I think I am going to embark on the journey of finding old and battered disks and using my contacts to remove the old finish and have them printed with in black and white.
These will obviously not be exact reproductions with regards to process, but the aim will be to have them indistinguisable from the originals and ideally a little more hardy as the plan will be to UV print them.
My main barrier will be economies of scale, as even rough date disks are not cheap ($50 AUD I think would be the mimimum) and whilst thats not a hug barrier, the main issues for me right now are:
1. Getting a sufficiently decent one to perfectly replicate the artwork
2. Designing the print template were the disk can be aligned with sufficient precision to ensure perfect alignment in the date window
3. Hopefully trying to get my hands on enough date disks to make it economical. However even if I pay a fortune to do 1 or 2, that will be my path. Its just nice to be able to do a small run to amortise the cost of the setup and print a bit.
4. Understanding the ideal process to prepare the disks for print (I assume acetone will probably be all that is needed to prep the brass)?
This is all relatively proven territory for me as I have done this for a few of my audio projects already. However this clearly is down to a scale that I have not done before.
My aim is to do this all ont he flat disks, not the curved.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
