More balance problems
SiZi
I am trying to restore a small lot of Soviet vintage watches - RAKETA 2609 and Pobeda/Zim/Slava 2602. On all 3 watches, I am having the same problem - the balance does not do a proper free run when I screw the balance bridge down. After messing up a bunch of hairspring’s I ordered a new one from Cousins. But the problem persists as you can see in the video below. I have tried shimming from different angles and with different thicknesses but it doesn’t help. Any suggestions are welcome, thank you so much!
Edited by SiZi
I can't quite tell from the picture, but that does not look like a Soviet shock setting to me. It looks like an Incabloc setting, which would not be compatible; I would expect to see the "zig-zag" style shock spring there. Can you show a clear up close photo of the shock spring?
I have never seen an Incabloc setting on a Russian watch, but maybe someone else has.
That's the correct spring.
Edit
@SiZi Can you confirm it is just a 2609
Edited by AndyGSi
Actually, the problem in the video is hairspring pressed on the balance arm. See the white circle.
You can see small amplitude oscillations with high frequency, this is because the hairspring is 'shortened', only small part of it acts as spring.
The way to solve it is to twist the spring near the stud as to lift up the place where it is touching now. This can be done in place, as the tweezers can grasp the spot and in the direction of twisting the tweezers movement is not limited by anything
I've no idea how old @nevenbekrievis, but his eyesight is better than mine, even with glasses.  Hehe.
  Must be all that carrot juice neven drinks with his breakfast.
 Lower coil looks good, perhaps spring leaves the stud with wide angle. We best see pic of spring end attached to the stud, before OP ruines another spring.
 Russians made watch out of parts they had in inventory, so we see variety of makes, not necessarily  variant of a base calib, but  with all sorts of shock system, hairsprings, balances wheel etc, whats  worse is their watches tic  , even kept time.
LOL for the last week I've had a Raketa movement sitting on my timegrapher, running dead flat at 280°/245° in 4 positions and it isn't even complete. Missing an escape wheel upper cap jewel but still no real variance in DU/DD.
Thanks everyone! The reason I showed the second video was so that you might be able to see that, because I suspected that was an issue BUT when I remove the balance cock screw it didnt seem to matter that the spring was resting on the arm. But you have now explained that 🙂 let me try and address this and report back. Thanks again everyone!
Well, this is no problem to see something when it is on computer display and actually enlarged 10 times than normal size. Here the balance behavior is misleading as untightenning the screw makes the problem disappear. In reality one would check the axial free play and understand that this is not the problem. May be my eyes are trained and immediately spotted the high frequency oscillations and when one knows what it means, then He will know where to look at for searching the reason.
You can see russian watches assembled from variety of different looking parts, buy this is because people assemble movements from what they have and sell them, thus You see mixtures of parts made in different factories and in different time periods.
I know a lot of people slag Russian watches off for being of poor quality, I have no idea if what is happening in Ukraine influences this . But i think they work pretty well and make good cheap watches for learning on.
It still doesn't explain why tightening the cock screw down almost immediately halts the oscillations. Still appears to be an endshake issue, so you could verify this by removing the hairspring, if you are brave enough ? What were you using to make the shims sizi ?
Or remove the top cap jewel.
Rich, untightenning the screw makes the cock go up, the hairspring goes up with the cock too and this is enough for the balance to be released
 According to the OP, tightening cock screw doesn't stop the oscillator ,   just prevents a proper free run.
 Once there is some end shake,  one should investigate , for broken jewel, bent pivot, or rubbing of hairspring on spokes,  balance rim on fork cock, pivot shoulder on chaton and fork on roller table, for possible cause of hinderance to oscillation.
Thanks Nev, as always it's interesting to know the reasoning behind your prediction. There are often many causes for the same issue, it's becoming less surprising to see you pin-point it first time 🙂
23 hours ago, mikepilk said:
Well spotted @nevenbekriev
Why did we not spot the obvious?
I, (and all the others who posted above) hang our heads in shame 😰
Lol we shouldn't really Mike, Nev holds some of the most extensive experience and knowledge in the group.
Edited by Neverenoughwatches
I'm dying to know what happens without the hairspring attached.
13 minutes ago, RichardHarris123 said:
Could the stud be in the wrong position? Would pushing the stud up in the holder work?
Yes, it could help. But the correct solution is to make spring parallel, as it now is tilted. The spring vibrates and changes it's position when position of the movement changes fast, so it is good to have safe distance around it, and it is easier to achieve when the spring position is by the rules - parallel and correctly centered.
49 minutes ago, Neverenoughwatches said:
...Nev holds some of the most extensive experience and knowledge in the group.
Well I felt a little overestimated here ☺️
On 12/14/2024 at 8:01 PM, Neverenoughwatches said:
As OH said the raketa 2609 and variants often had a brass shim or two under the balance cock. Yours might have its missing, although may just not have had one.
Mine has score marks instead
Let me take videos and share. I suspect it’s an end shake issue because I noticed very little of it as part of my routine inspection checklist and that’s why I tried the balance free run without the screw. Let me try (a) without the hairspring, (b) without the jewel.
I agree, this is an evident issue so I should address it before anything else. I’ll attempt to do this as well before reporting back.
by the way, I managed to get it running free (like it was without the screwed down cock) by adding a thicker brass shim. But since I am using this movement to learn, I want to address the problem properly and not just bandaid it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
