How to correct Westminster Chime Sequence?
dnhb
I have received a mantle clock in which the chime sequence is wrong & the single strike on the 1/2hr is missing. Counting away from the back plate the sequences I observe are:
1/4: 1342 (instead of 4321).
1/2: 4321, 2431
3/4: 2342, 4231, 1342
Hr: 4231, 2431, 2342, 4231
The only pattern I can detect is that the 2nd group in each of the last 3 lines above should be 1st.
I'd be grateful for advice as to the procedure to follow in correcting this: I imagine I could make things much worse by trial & error!
1/2: 4321, 2431
Photos please.
I think that if 4321 is the descending scale then 1 will be the longest rod. The clock is four chimes ahead and resetting is not difficult. You can try to do it with the movement still in the case, which I'll describe first. But it is likely you will need to take the movement out to do it.
To correct it without removing it from the case, stop the clock and move the time round to quarter past and let it play its incorrect sequence.  Depending what the make is, there will be a way to disengage the chiming system from its train. Usually you need to remove a wheel on the outside of the back plate. If you can do without removing the movement you are lucky! Once disengaged, manually turn the barrel (with pins or studs on) and listen as the hammers hit the bars. As soon as you hear the descending scale, stop and reconnect the hammer system to the train by replacing the wheel.
If you have to take the movement out you do the same as above but will need to look for the descending sequence rather than listen for it. If your chime rods are in ascending order then look out for 4321. Now reconnect the system to the train and run it a few times. Check that the last hammer of every sequence drops (they can stay high and dry if you didn't move the barrel enough) and check also that when it goes into warning (a couple of minutes before it chimes) that the hammers don't lift (if they do it means you moved the barrel too far).
Like Andy asked, send some pictures and we can give clearer guidance.
OH, I played those notes on the piano - not a tune I recognise!
12 hours ago, oldhippy said:
Here you are.
I'm a bit confused by this.   The usual Westminster chime requires only four notes,  and can be played on four chime rods.   This list specifies 7 chime rods.   Also the first quarter usually is played in descending sequence ( 1234 or 4321,  depending on which direction you have numbered the rods.)
I just tried playing those notes on the piano,  and they don't sound like any chime I have heard before.
Could this be referring to some other chime sequence?
13 hours ago, Michael20 said:
This one seems more like the chime sequence with which I am familiar.
Thanks so much, Rixy. Took the movement out & followed your guidance: only needed to move the barrel through one set of pins. Was consequently able to take clock back to owner & set it up for her.  She's texted to say she's so pleased to hear the Clock going again: the sound takes her back to her childhood when she last heard it! Very satisfying....Thanks again.
On 12/16/2024 at 12:31 PM, Michael20 said:
Hi dnhb, I am completely self taught so maybe others will spot an error in what I am about to say - I have done this once by following instructions I found on the internet. I made some notes based on those instructions which I'll attach.
Thanks, Michael: You have a good teacher!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
