Gustav Becker 400-day clock losing time
Millaram
Good morning all. I am a clock novice trying to get a Gustav Becker 400-day clock running. It belonged to my father and as far as I know, he never had it running. I have read a bit online about setting up these clocks - daunting - so I may give the impression that I know what I'm talking about but don't be fooled. It's called talking a good game!
I am told that the clock is fitted with the correct suspension spring (0.004"). I don't know if it is the correct length. The pendulum sits approx 1/4" above the base. I think the fork is in a good position as the clock ticks steadily and there is no flutter. I have moved the adjustment weights on the pendulum fully in to get it running as fast as possible. It runs for days but runs slowly. It loses approx 1 minute per hour.
Does the length of the suspension spring affect the timekeeping and in what way?
How much of a difference in timekeeping can I expect between having the pendulum weights fully in and fully out?
Any suggestions about how I might get it running faster will be welcome.
Thanks
Alistair
Okay I have a few GB’s and every one has to have a thinned 0.0045” torsion spring as they are all somewhere between 0.004” & 0.0045” , the book states 0.004” but I have never found one to take that , As your clock is running slow that points to the same wrong torsion spring, I have done a video how I thin a torsion spring along with lots of other torsion clock videos, here is the thinning video.
Dell
    • Dear WRT Community, My name is Ben, I am a watch enthusiast learning about watch servicing and repair thanks to Mark‘s course. I started a while ago and I am progressing at a very slow yet enjoyable pace. I look forward to exchanging with you on this forum! Ben
    • I wonder if they ever got the back off, dug mine out today for a change.
    • …here’s a factory shim on a supposedly high quality movement…as I said it’s a lovely shim, though…
    • Bending the balance bridge does seem to be an acceptable method as is taught in school and after all the Swiss make a nifty tool. But? Something was bothering me this discussion has gone on for five pages for one watch? One of the things we have to be very careful about when teaching watch repair on a discussion group is our observations of what's going on is based on the posting person making observations. The problem is if the person making observations does not actually grasp 100% what's going on will we become the idiots? so for instance bending the balance bridge why would we do that? Typically if it's been bent by somebody else and were restoring it back to wherever it's supposed to be. Or basically the Swiss are using it to fine tune the end shake. But it appears to be if I'm reading correctly we have a variation of 0.5 mm which is not a minor amount of end shake. this is where when you read five pages of discussion it becomes kind of a confusing mess so I would not recommend bending the balance bridge until we figure out exactly what's going on. So while I'm not a big fan of shimming which is extremely popular with @Nucejoe I do think it's perfectly acceptable until we actually figure out what's going on.
    • ? I don't know what you mean holds the arms ? The internal spring in the spindle should allow it to hold up to the rivet and the hub of the staff. But that means taking off both the collet and the rolle. With a figure of 8 calipers that have the correct nibs fitted you don't need to do that to true a balance wheel.
