Replacement Crystal for an Orient watch
By watchweasol · Posted
Hello Josh , wellcome to the WRT community where help is always available TZIllustratedGlossary.pdf -
Hello Vessel18 and welcome to the forum , a place to stay and enjoy. You are starting out. In the right place with Marks course. A little additional reading for you TZIllustratedGlossary.pdf TM 9-1575.pdf -
On can only concur with Joel’s comments, where else can you get such inspiration and help. A magnanimous gesture indeed. Thank you -
Hi it’s probably a snap back. I have found Tissot backs very tight and need a case back tool to clamp the movement and pry the back off. Conversely you will naad the case back press to get it back on again. Both on eBay or Ali Express. -
the coils on those movements always gets damaged, that is probably the issue....
