Hairspring adjustment.
Okay... Every now and again I get a desperate customer who really doesn't want to send his very expensive watch back to it's respective workshop.
Apart from needing a full service, the hairspring is definitely in need of adjustment. Can this be tweaked back into the centre? Where on earth do you start?
It looks like someone else has had a go as the bridge connection/regulator pins doesn't look right.
Let me be clear, I'm not terribly efficient in hairspring adjustments but if this is an easy fix, I'm willing to give it a go.
Your advice always appreciated. Even if you tell me to put it back and close the case, I shall do so.
Hi mate,
It's always good to tell us which movement this is. You'd then also probably be able to find pictures online of a balance/hairspring and how it should look.
That being said, I think this hairspring is only bent in the area of the regulator pin (most common location) :
Hi there,
Thanks for your help.
The watch is Fabergé and the movement is by FP Journe (calibre not yet known). It's a lovely watch as you can imagine!
A small update. The hairspring had a tiny fracture right at the adjustment stud. Just a tiny nudge and it snapped!
Due to it being a gold case, I can see a dent on the side meaning it's had a fall and quite possibly caused more damage than the hairspring.
It's out of my remit now so I'm returning to customer undone.
2 hours ago, Hiren said:
Hi there,
Hairspring work is a big part of watchrepair and hairspring issues are undoubtedly the most common of all faults in a movement. Searching the word hairspring in the forum archives I bet will show more results than any other enquiry. You haven't said what your role is with watches but I see you have been a member of the forum since almost its creation. Learning to repair hairsprings is really a must with watch repair.
51 minutes ago, Knebo said:
Whoa, are you serious!? Please share more pictures!
That must be a 5 to 6 digit price tag.
The balance assembly didn't look anything special, in fact the underside of the cock looked very plain and a bit scuffed up ??
If thats the quality of a 6 figure watch...then I'll stick with BFG s 😂
🤔 its not even an overcoil, looks dodgy and fake tbh.
Yes, I thought the same!
Hence me request for more photos.
I took for granted that the information we received was correct—typical Swedish behaviour 😒 But I remember thinking that Rolex movements must be very affordable in comparison. (Free-sprung, overcoil, microstella screws, etc.).
11 hours ago, nickelsilver said:
Journe doesn't supply movements to anyone, I'm guessing this is an F. Piguet movement.
Yep, you're right. My bad on that one.😣
Sorry, my mistake.
F. Piguet... 🤦🏽‍♂️
During my initial venture into horology, I wanted to study mechanicals. I started moving away from it only because of time and expenses.
I'm actually more proficient in polishing and refinishing on jewellery and watches now. I do the odd quartz service too and this is a nice balance between watches and jewellery. I'm happy where I am at the moment as my two passions are monetising and I'm quite content.
My daughter seems interested. She's got a couple of years before deciding a direction. Perhaps BHI or WOSTEP may be her calling?
I expected to see something of that nature on the balance, although there is an interesting screw on the stud holder , like another position for the stud set further in ? Sometimes, quite often even , a product only needs an exclusive brand name attached to it to command a high price tag.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
