Seiko A-201 caliber stem pulls out when setting time
By watchweasol · Posted
Hi it’s probably a snap back. I have found Tissot backs very tight and need a case back tool to clamp the movement and pry the back off. Conversely you will naad the case back press to get it back on again. Both on eBay or Ali Express. -
the coils on those movements always gets damaged, that is probably the issue....
an investment in assortments most likely from a seller like Ebay will be a good choice, I have seen several this month already sold, or a donor if your supplier does not carry something suitable....
What have you tried? Is there any indent around the back?
