I've been asked to look at a small platform escapement mantle clock because "it keeps stopping". On receipt it stopped within a few minutes when placed upright but ran until wound down when on its face or back. Now it runs upright without stopping. It seems that the platform has been replaced by one that isn't the same as the original (see photo - I've added the white plastic sleeve to allow the hands to be moved).
The 2nd photo shows a label on the inside of the back cover with a previous repairer's shorthand which I'm hoping someone can decode for me.
It also shows a broken part that came with the clock - would this have been part of the original platform unit?
Compliments of the Season to all.
What an utter mess.
Wrong size platform that has been in- correctly fitted. This has been taken from another movement you can tell by the mess of the screw fixing holes. Sounds as if it could be a depth problem. I need to see the whole works to see If I can spot something.  I wish you could prove that it had been sabotage by those whose name is on the ticket. I can assure you he is no master clock maker but incompetent. That part is a part of a regulator but not from this platform.
Edited by oldhippy
This is strange. After Richards post I thought I know of that person so I went to his web site and thought something fishy here. I have watched his videos and interviews and seen his work and I must say no way would he have done this sort of thing. He is highly respected in clock making.
Well it isn’t pretty that’s for sure, Iam sure somebody else has had a go, the  label maybe his but I wouldn’t blame him for that crap job. If he is accredited to the BHI no way would he produce work of that natureents.
The ticket I have worked out as follows apart from M C T
Date November 2016. O/h = overhaul M/S =mainspring. ‘scap’ = Escapement
Ref No is the ticket number which the owner would get. Smith is the owner’s name.
Service due November 2021
Expand
The clock was passed to me by an intermediary a few days ago & because it's been Xmas I've not yet spoken to the owner (& I've not been allowed by SWMBO to examine it closely myself!). As a reputation is involved here, I will report back when I've done so.
Expand
Cf my response to OH in this reputational issue.
  On 12/27/2024 at 7:57 AM, Klassiker said:
It's worrying then that he is on the BHI accredited clock repairers list.
Expand
Please see my response to OH.
Expand
I've now been able - in a quiet moment! - to get a couple of shots of the movement (The back plate indicates it's French). I've circled, in the 2nd one, the break in the regulator ring which seems to match that of the broken part shown in my initial post.
Having now spoken to the owner I understand that the 'cuckoo' of an escapement platform was already fitted when the owner inherited the clock but it was not running at all at that stage. In overhauling it etc [thanks for the decodes, folks] the Clockmaker (Taylor) found the broken part of the regulator ring in the case. On return the clock ran (slow of course) for ~ 18 months & then stopped. On trying to claim against the guarantee that had been given, the owner was told that the clock had "obviously been dropped" which the owner denied. There the matter rests. I have found a replacement regulator which looks like it might fit & the owner has asked me to explore this possibility. However, the work is at the edge of my comfort zone: I have previously disassembled a balance assembly but in that case the regulator etc was secured via 2 screws under the cock whereas this one seems to be a press fit via 2 studs. Also, the gap (arrowed) in the ring bearing the stud arm suggests that it needs to be pressed onto the central pivot jewel  boss. Before I go any further I'd appreciate advice e.g. as to whether the stud arm ring can be gently prized off from the top of the staff or whether the boss can/should first be removed.
  On 12/29/2024 at 3:10 PM, watchweasol said:
Hi. The regulator will pise off . I would remove the balance from the cock before attempting any work and if you decide to. Prise it off ,do it in a plastic bag to minimise the flyers.
Attached some info on platform escapement repair
Expand
Very kind of you to look out & attach the article which has not only given me more confidence but also taught me that one can/ should rotate the regulator 'boot' to release/recapture the hairspring! Fortunately it's stud pushed out easily & it & the balance are somewhere safe but I've yet to get anywhere with the prising operation - the boss seems very firmly seated. However my efforts have so far released the other part of the regulator (see photo) & now I'm wondering if this is repairable....
That piece has broken.  Agree with it being French. I cannot understand Taylor leaving the movement with that poor fitted platform unless the customer didn't what to pay for a proper size platform. I still think it could be a depth problem I admit it is a job to see the teeth that run with the escape wheel, that is what you need to look at.
  On 12/30/2024 at 4:40 PM, RichardHarris123 said:
Post a photo of the other side.
Expand
Thanks for your interest: photo of obverse attached. Notes: the previous photo shows that the 'pin' opposite the regulator boot has been broken off; and the (broken) ring is not contiguous with the regulator lever which,  on the basis of my v limited experience, surprised me - so it's not clear to me how the lever would rotate the ring.....
When it is working correctly moving the tail auto moves the part that has broken, but you can also move it manually.  It is just friction that works it.
Edited by oldhippy
Hi.  I have done this before on watches, the stud arm comes off and the regulator arm lifts off.  Screwdriver in the slot opposite the stud and open carefully as it’s hard, it should lever off leaving the regulator arm.   From the underside there looks to be two screws ?.
  On 1/1/2025 at 12:12 PM, RichardHarris123 said:
I might be stating the obvious but does the regulator arm need rotating so the centre part alignes?
Expand
Well, I've just tried that but the arm doesn't move the part you've indicated. Nor can I move it directly at least with the (small) amount of force I've tentatively applied (c.f. if one doesn't know a door *will* push open....!).
Expand
I was wondering whether to try that but from what I can see (photo) the stud arm ring sits under a flange which makes me worried that the ring will snap before being released (especially given what's happened to the regulator ring). As far as I can see there are no screws (as indeed there were on the other balance cock I've disassembled) & my assumption is (based on other comments & the apparent pointlessness of thus 'burying' the screws) that the assembly should lift off the brass base. As previously reported I've yet to devise a successful approach to the necessary prising operation!
  • 2 months later...
Expand
Coming back to this after being busy on other things, I have managed to prise the stud/ regulator assembly apart by a little gentle tapping on a craft knife blade once I'd found the right spot to position it. So it now seems (to me) worthwhile to think about how I could possibly reconnect the two arcs of the broken regulator arm. I'm wondering if solder would be strong enough or whether braising would be necessary; or if there is any other approach to securing the functional regulator element to the balance cock. I'd be grateful  for suggestions....
As the regulator is made of sprung steel any prolonged heat will anneal it and make it soft , laser welding such as carried out by He tor  would probably work.  But where you would get it done other than at a friendly jeweler I know not. Probably best sourcing a doner watch on eBay if possible.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently! Another option:
