On 1/3/2025 at 8:39 PM, AndyGSi said:
parts are made in China
Maybe, but if they are Selitta branded they are swiss specified and swiss quality controlled.
On 1/4/2025 at 3:39 AM, AndyGSi said:
The movements may be made in Switzerland but I expect this is correct and the parts are made in China.
I just hope it's really made in Switzerland. If it's made in China, it will be the same as the practice complete automatic bridge I bought but alot cheaper.
Edited by boogeez
Where did you get this and how is it listed?
We have a local website similar to ebay which you can get almost anything. The one I got came straight from china
Edited by boogeez
Hi.
Hopefully someone can help. The practice bridge was easy to assemble and disassemble. My problem is I can't remove the 2 screws on the bridge of the watch. I'm just scratching the screw head. I tried different sized screwdrivers but it won't budge. What screwdriver size do I use? ty
Thanks in advance.
Edited by boogeez
I think it's a 1.0 or maybe even a 1.2 mm blade you need. It should match the diameter of the head without scratching the surrounding metal. Then you need to dress the taper to fit as deeply as possible into the slot without bottoming out. Once you've done that, use plenty of downward force on your screwdriver, and as much torque as you need to release the screw.
Thanks for the advice. How do I "dress" the taper?
If your screwdrivers are new they are probably not sharp enough. A too-blunt driver will sit on the slot rather than in it and be unable to turn the screw. But don't think you should make it as sharp as possible as if it is too sharp it will bottom out and be loose in the slot. In that case it is likely to slip out of the slot as you try to turn it, bruising the screw and potentially scratching the movement. You should be able to see the driver sitting in the slot, and you should not be able to turn it at all without the screw moving.
I've been doing this for about a year, on and off, and am only now coming to properly appreciate the importance of correctly dressed screwdrivers, and the need to be willing to adjust them for different movements so that the stone is starting to get used quite frequently. (More experienced watchmakers will likely have several different sets, each adjusted differently; I have just the one set.)
I have a sharpening tool similar to the one linked above, but I don't find it particularly helpful compared to holding the tool on the stone by hand, and using magnification and feel to make sure it is sitting straight.
  • 4 weeks later...
Update on my Oris.
I was finally able to get all needed oils, parts and better screwdrivers( Bergeon 30081 from 0.8-1.6 size). The screws still won't budge. The screwdeivers just slip off. I tried from lower to higher size screwdrivers and nothing happened. Any suggestions please. ty
  • 4 weeks later...
I was finally able to get a stone to get the correct fit for my screwdriver. It fits the slot perfectly ( no wobbling, no slippage). Used a firm grip and pressure to remove the screw but still no luck in removing it.  I don't know what else to do.
What penetrating oil should I use?
A few questions regarding this.
1. Won't the oil go to other places making it necessary to service the entire movement?
2. Is there a way I can cut the head of the screw without damaging other parts from vibration or dust/heat (ie. dremel)?
3. I wanted to try and glue an old screwdriver to the slot using cyanoacrylate then screw it out when it dries. Anyone try this method?
Thanks in advance.
In answer to your question.
1. Yes I'd expect you'd need to do a full service.
2. Don't think so, again without having to do a full service.
3. I wouldn't expect superglue to give you any more purchase on the screw than you've already got.
Not sure if it's already been posted but what are you trying to achieve here?
Edit
Rightly or wrongly you should be able to apply enough force to this screw that would shear the head if it was so tight.
Edited by AndyGSi
I have done something similar to this on "regular sized" seized screws. I place a nut on the head of the seized screw. Place some superglue to glue the screw head to the nut. Wait for superglue to dry. Use a socket wrench to remove the seized screw. ( the screw is then replaced with a new one).
FYI. I already have replacement screws that hold the bridge.
How about touchimg the screwhead for a few seconds using a hot soldering iron?
Actually, one of the screw heads is getting lopsided from the pressure and torq I'm applying.
Edited by boogeez
Regular size seized screw require a lot more torque to snap, and like I said, you should be able to apply enough force to snap these with just a screwdriver.
Thanks for all the help AndyGSi.
I'm just a little afraid to snap the head off only to find out that the screw cannot be backed out using tweezers or something similar.
I must admit, this has got me beat. I have no likely explanation why these two screws will not release on a movement which is only 5 years old, in decent condition, with no signs of rust. Sorry to ask, but are you sure you are turning them the right way, i.e. anticlockwise?
The only thing I can suggest is to strip as many of the other components as you can from the mainplate and then use a combination of penetrating oil, impacts and heat from a soldering iron to break down the bonding.
Unless you are prepared to use it as a manual wind you have nothing to lose. The movement is only good for spares as it is.
  • Sad 1
The only explanation I can think of is when the original damage was done to the boss the bridge has twisted and that's what's jamming it.
I think the problem is they don't have the knowledge or experience to risk digging into the movement further.
Yes. I'm sure it's lefty loosy/anticlockwise. I am already using alot of torque to loosen it.
That's what I plan on doing. (Using it as a manual wind).
That could explain it.
I'm just a newbie tinkering with a sellita movement. Will probably send it to an experienced swiss movement watch repair technician. Hopefully he has better luck than I do.
At least I gave my best at this time. Thankfully got better watch tools for use on other watches when the need arises.
  • Similar Content
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
