How? It's an old Oris watch that works, but could do with a clean and probably a full service. Bracelet ends shown in the pictures. Doesn't appear to be spring bars - if they are I can't shift them.
Is there a non-destructive way to get it off, or should I decase the movement leaving it intact?
you can see the springbar under the band end-piece, it is frozen, both sides should have the same hole, try the other side and or soak/tap....it looks to be a brass plated springier
