I recently bought a watchmaker's estate.  Among the spoils are bins of unbranded watch parts: balance wheels, third wheels, fourth wheels, cannon pinions, etc. etc.
I can see the value of bins of screws, staffs, crowns, etc. but the rest boggles the mind.  What is the chance that some random third wheel will fit an Elgin 6/0 movement (for example)?
Am I missing something.
Its possible. One thing I have learned when sizing and cutting wheels, is the module and diameter are very important to get right. I'd like to think that most watch manufacturers had some set size and module they used universally, but I haven't taken the time to measure my assortment of wheels to find out. You could sort them by tooth count I suppose, then move from there. But the entire train is dependent on how many teeth the main barrel has, and its designated beat rate it wants to achieve. Plus the pinion on the wheel will need to match what the watch you're using it for needs it to be.
From my understanding, the first thing they do when designing a train, is calculate the tooth counts, then select a module to cut them to. The final diameter is kind of the product of those two. So I'm not sure if two different wheel manufacturers would be the same. Could always fire up the lathe and make on yourself!
Part of my long term plan, but not sure I will ever get there.  Would love to see your gear cutting setup
It is often possible to make a wheel that is missing by assembling table from one wheel and pinion from another. You will need to figure (or calculate) the OD and teeth count of the pinion and table and then search the collection of wheels You have. The bigger the collection is - the better.
Interesting...but I will have to count teeth until the cows come home!!
17 minutes ago, RichardHarris123 said:
they could help counting teeth.
As long as it's fewer than 32 or so.  Escape wheels or pinion leaves.
Counting teeth is something that I often do. One reason for such counting is to determine the BPH of a movement. Another reason is to determine parameters of missing wheel. Another - when something is obviously wrong with timekeeping and the BPH is correct for the movement - then always gets clear that someone put wrong wheel(s) and messed things up and got rid of the watch... It mus be clear that not only teeth count is important, but correct mesh is needed and coincidence of modules of wheels/pinions. A lot of reverse engineering is needed in antique watches restoration sometimes.
I suppose, when I run into the situation, I will sort by diameter first since it is quick.  Then sort by pinion, and then by teeth.
35 minutes ago, RichardHarris123 said:
Having a box with random parts seems like bad practice to me. Keep a parts movement in tact, place in a  zip lock bag and label the caliber.  Only one part left, do the same.
Agree.  However, somebody thought differently and I now have lots and lots of parts sorted by type (wheels, balance wheels, pallet forks, etc.).
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
