Hi everybody
Doing a service on a 1980s Hellbros watch with a  French movement cal. P75A and I've never seen these kind of balance staff jewel shocs before, and don't know if you can or should remove them to clean/oil. Wouldn't have a clue how to get them out anyway. They have what appears to be 3 prongs holding the cap jewel in place, but I see no notch or slot to rotate to, to get the spring out. They do rotate freely though. Sorry for the crappy pic. My phone has a lousy camera. Have to do the old pinch and zoom trick.
Need some help thanks.
Mike
Edited by MechanicMike
Spelling police
Can you get a clearer picture from directly above please. There are a few similar to this one with prongs. If they are sharp pointed then it's probably a Ruby Neutro Shock. They are quite common in a few Swiss movements, so as you can imagine this question pops up regularly. Last time it came up I decided to strip one down.  I'll see if I can find the thread.
https://www.watchrepairtalk.com/topic/28824-as2066-balance-staff-jewel-cap-spring-adjustment/?do=findComment&comment=243648
I tried getting a clearer and more magnified pic but like I said, my phone camera is really bad and as I try for macro shots the view gets worse and completely blurry. Believe me-I've tried several times for better shots. This one turned out the best. If you open the pic up with your fingers, it gives a closer look and yes you can see the three prongs. I had no clue the name of these things-first time working on this type of movement. Thanks for the info. 👍
Some phones you have to back up a bit and then zoom in.
2 hours ago, mikepilk said:
The movement is Lorsa P75A,  https://ranfft.org/caliber/7711-Lorsa-P75A, , which mentions Antichoc.
You can get surprisingly good pics by holding a loupe over the camera lens.
I'll try that. Thanks! Good tip.
Tried that. Didn't work. I'll keep playing around with it. I used your link and read your stuff. I posted there too. That's definitely the culprit.
Did someone already post this? I found a data sheet on Antichoc 108 showing that  it should have one horizontal protrusion and also a vertical one, so some combination of rotation and upward pull might do it. Epsilon_Antichoc_108.pdf
Tried that. Even my older version of my phone did better than this one.
Yep. I had forgotten to mention Lorsa.
I looked at the spec sheet and I tell ya, under microscope it doesn't look like it would be a pleasant one. Neverenoughwatches had tried to go deep on one of these and remarked that it was darn near impossible and basically an "enter at your own risk" kind of deal. I decided not to attempt it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
