Well, the local auction had this up for sale, got it for £55 in fully working   Condition.
Now I’ve done some reading through past posts on wiring, heating elements and so forth, I have come to the conclusion that baskets are the main problem.
Now mine doesn’t have any, so a Quick Look on eBay and I’ve found some generic baskets that I can fit.
I have ordered a 20cm length of 15mm diameter alloy rod that I’ll mount up on the lathe and bore an 8cm diameter hole 5cm deep and drill and tap a hole for the grub securing screw.
Once that end is done ( motor end ) I’ll turn my attention to the basket end as I don’t know the inside diameter of the hole on the basket frame. But once I do I’ll turn the rod down and again drill and tap a hole to secure the frame to the shaft.
The machine does take up a lot of space on the bench so it might have to live in the garage with my clock cleaning US tank and rinsed and steam cleaner and other bulky tools.
Hopefully I can make it fit, if not it’s out to the garage.
I have this same basket that I used for my automated machine. Its ok, but the compartments in the individual baskets are not seated on the bottom, which allows thin parts to move to other compartments. I plan on using it still, but im printing a new basket to use on nicer movements to its doesnt scratch, and keeps the parts separate.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
