On 1/7/2025 at 12:03 PM, Knebo said:
- Yes, it's a spring that presses against the centre seconds pinion to prevent jerking/jumping of the seconds hand.
- But no, in this movement it's not from the top (like Omega 55x or older Rolex), but from the side. Here's a picture of the underside of the barrel bride. The green dot would indicate the place where the centre seconds pinion will be located and the green arrow the direction that the spring pushes against it. I find this solution more elegant and less tricky to adjust than the "from the top" ones. On the other hand, one has to be a bit careful when installing the bridge (see technical guide comment on Fig 7).
On my first assembly of this movement, I “managed” to have the spring at the wrong side of the pinion. It can happen easily. The jerking sweep second told me about the mistake.
Edited by Kalanag
Yes, it can happen. I was aware of the risk before assembly, having read that part of the manual. It's easy to avoid misplacing it if you nudge the spring in the right direction through the "window" in the bridge. I think the window is designed for that purpose.
On 1/7/2025 at 12:12 PM, Neverenoughwatches said:
I think @nevenbekrievmade his point then, the UK has had quite a few 0°C this year, quite tolerable really....for me anyway. At 0°C HP1300 has 3x the consistency of honey and half that of treacle at normal room temperature.  If the balance gets anywhere near 0°C then it ain't moving. My next experiment is to oil bal cap jewels with honey 😁
As it is -3°C this morning, and I'm currently wearing my latest project for timing (Memostar AS 1931), I decided to measure the case temperature after a walk, to see if the oil turns to treacle as you and Nev suggest.
Using a thermocouple, the case temperature measured 25°C. Not surprising, as body temperature is about 36°C, metal is an excellent heat conductor in close contact with skin, and the watch is under clothing.
So no need to worry about oil turning to treacle 🤣
What I mean is that a person (may be customer) may leave His watch in a cold room or another cold place for awhile, may be whole  night, and then find it has lost several minutes or even stopped. Then go and explain Him that the watch has to be always hot in order to run normally...
Alright alright😅, I just put the watch in the garage. I'll see tomorrow morning if it gained/lost a lot of time. I'll also take an amplitude reading tomorrow when I get it from the garage - and then after it warms up.
I'll report back!
Ok, results are in @nevenbekriev, @mikepilk, @Neverenoughwatches et al.
1. The watch didn't lose/gain more time in the garage than in my watch drawer.
2. Amplitude loss when at 5°C (garage) vs 22°C (after warming it up) is 20°.
Straight from the garage:
After warming up:
(note: background lightning difference is due to curtains being closed/open)
After warming up:
Good Experiment Knebo,  interesting that it was starting to reduce the amount of swing just not enough to affect the rate. I wonder if with 9010 it would be the same ?.........if you'd be so kind as to.......🤣
Just dont take it with you on any Antarctic expeditions you might have planned 😉
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
