Hi
The battery clamp was defect when i bought it. How can I test if the movement works before I buy a battery clamp?
Can I use a digital multimeter?
There is reaction when I put the red and black needles on the battery + sign and on the upper end the magnet thing
Just use a pair of metal tweezers to bridge between the battery and when the clamp connects.
Edit
I'd also look at alternatives before paying the Cartier price for one.
Edited by AndyGSi
Edit
You mean like this? Nothing happened.
Yes that's the idea but not sure if you'll need the correct size battery as I don't know if it is just the base that needs the +ve contact.
Have you got any other test equipment apart from a digital multimeter? Ideally it needs to be an analogue one.
I dont have the correct battery in stock, but know from previously it works with smaller battery. I unfortunately dont have analogue instrument. Hmm dont know what to do from here🙉
I think the Cartier 81 is a 2 hand movement and pulses only once every 20 seconds.
If you don't have any other test equipment, adjust both of hands together, then connect the battery and wait for at least 1 minute and see if the hands moved apart.
I think all you can do is put it to one side until you've got other test equipment or can find an alternative clamp with the correct battery.
Still not working🤐
7 hours ago, HectorLooi said:
Remove the circuit board and use your DMM to test the coil resistence. It should be around 1 to 3 K.
Why do they have to remove the circuit board to measure the coil?
Because the contacts are covered by the circuit board. And I wouldn't want to risk breaking the wires by jamming a probe into that little gap.
These are the coil connections.
Edited by AndyGSi
13 minutes ago, HectorLooi said:
Yes. And you see the 2 thinner than hair wires protected by blobs of epoxy.
I wouldn't go probing anywhere near them.
Yes you have to be careful but that's what they're their for as this example below.
9 minutes ago, HectorLooi said:
Nah! That's just the manufacturer's ploy to sell more coils.
We'll that's now I've always measured them and never had a problem.
Maybe the circuit board is the problem?
Because I see some wear on that circle to the left from the number in the bottom.
Should I use the conductive pen here?
And I have also checked the upper to sides of the coil with the digital meter, I guess its ohm to be checked? But no response.
20 minutes ago, AndyGSi said:
It does look like there's damage to the pad and track next to it but if the coil is open circuit then that's your first fault to resolve.
I bet you are right. On the right end of the coils, I see something irregular as if somebody smashed in a screwdriver. So I believe this is a very costly repair if I ever go on with it.
It's nice to see when the coil is lacquered or resin coated.
If the break is near the end then there is a chance to reattach the coil from that point. It will affect the resistance.  I have never repaired one this way but I did have a go at unravelling one end a few years ago. Delicate steady handing cannot be overstated.
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
