I just did a rebuild and it was working fine but now the clutch will not mate securely with the winding gear so that I can not wind the watch using the stem and crown.  The clutch moves freely, the yoke is in the groove, the yoke spring is in place, The setting lever spring (cover) looks ok. I can click the stem in and out to all 3 positions but in the winding position the gears don't mesh fully. I removed the hacking lever thinking that was causing but the issue still persists. What am I missing?
