Beginner's Question re Schatz 54 1000 day clock suspension block
ChrisInOz
Hi Folks.
My first attempt to work on a torsion clock.
Last year I picked up this Schatz 54 1000 day for $12 at an auction where I was buying old wristwatches.   It has a broken suspension spring.
I dismantled and cleaned it during the last few weeks,  and am now in the process of assembling the new suspension.
I have the correct new suspension spring,  and the original blocks and fork.
Problem:  When I take the two screws out of the bottom suspension block,  I cannot part the two plates.   It feels as if they are glued together,  there is no give in them at all.
Looking at the plates under magnification,  you can see that the broken end of the spring is still between the plates.  See picture.
I was expecting these plates to separate easily after taking out the screws,  so that I could shake the broken piece out and insert the new spring,  but, no dice.
@DellIs there some technique for this that I don't know? Could it be that the last repairer glued the spring into the block?
I see that Cousins sells replacements for these blocks,  so I can always order one,  but I am keen to know if I am doing something wrong here.
Cheers,  Chris.
Hi Chris
both parts of the block are a tight fit on the pin on some blocks I use a blade to get it apart then broach one side slightly to make life easier in future, I have done a video of Schatz 1000 day restoration if it’s any help.
Did you remove the saddle? If you did then that takes a bit of setting up because it is also the eccentric bush .
Dell
Forgot add the picture of my 1000 day from video.IMG_1216.thumb.jpeg.3c5e696bce5e26305ed66f3782aa373a.jpeg
Yes,  I did remove it.  The clock was very oily and dirty,  so I disassembled the whole train (apart from the centre wheel which is captive in the front plate,) and cleaned it all manually in Shellite.
The last person who worked on the clock very kindly left a scratch mark on the plate to indicate the correct saddle position,  so I have put it back in the same place.   I won't know if it's right until I install the new torsion assembly,  but I have verified that the anchor takes an impulse from both pallets,  and it doesn't flutter.
Yes,  I watched it and it was helpful, thank you.  I also watched your video on installing a new torsion spring.
I have Terwilliger's 9th edition for the measurements.
Thanks,  I will give that a try.
Movement is now running on the bench with its new suspension.   It has been running for almost 5 hours now.
Time for me to finish the reassembly (dial, hands,  base and suspension shield,) and check on  the timekeeping.
Thank you @Dell for your advice.
Clock is reassembled and running now.
I'm still setting the rate, but as of this afternoon it was within 2 minutes per day.
Interesting that my clock has Arabic numerals, while the one that @Dell posted has Roman. I didn't know both options were available.
Edited by ChrisInOz
more text.
I am pleased with the time keeping on my one @ 1 minute in 3 months , much better that most of my torsion clocks approximately 1 minute a week ( normal ) apart from my Grivolas ( French ) about a minute in 6 months.
Dell
This is a Grivolas
That is really impressive. I would be very pleased to achieve that with mine.
Do I need to lubricate the impulse faces of the anchor at all?  I am running them dry at the moment.
I haven't oiled the anchor pivot jewels either.
This is what i used to do my watch oiler every other tooth of the escape wheel and on both faces of the pallets and to stop fluttering and to make it easy with the escape action using the same size oiler a wee drop each side of the pallet post that goes in between the pallet fork.
I used watch oil on both the pallets & jewelled pivots but I only put a small amount on the pallets as when the escape wheel teeth hits the pallet my thinking was that would spread onto every tooth right or wrong I am not sure but that’s what I did .
Must admit OH I hadn’t thought about oil to help stop fluttering but it makes sense, on torsion clocks the usual thing to stop flutter is to raise fork 1/2 to 1mm.
Dell
I just re-serviced two of my anniversary clocks which I oiled with Windles clock oil. I think the last time I serviced them was 4 years ago. Is this an acceptable duration between service?
This time I used all synthetic oils. HP1300 for the barrel arbor and 2nd wheel. Moebius 9020 for all the rest. I hope synthetic oils will give a longer service life.
I also oiled the suspension fork, which I learnt from @oldhippy four years ago. I found the inside surface of the suspension fork a little rough and I burnished it with a suitable sized screwdriver blade. This resulted in an improvement in the amplitude.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
