Junghans 98 stops running dial up.
Hello watchlovers,
I serviced a junghans 98 (1971, 7 jewels). As I started the mainspring was fully wound but the watch wasn't running. The balance moved freely. I disassembled the movement, cleaned al the parts, put it together and greased and oiled. After assembly the watch was running very nice (dial down) for about two days. The ampitude was about 260. The beaterror about 3.2. But, if I turn the movement, it stops running. I checked the jewels of the balance but I can't find faults. The wheels have no jewels. Is this a pivot problem?
Edited by Gaus
When you say stops, you mean stops immediately? No time to get a reading on the timegrapher? If you give it a shake, will it start running dial up, or not? What happens if you turn the microphone back to dial down?
My first thought is that the hairspring is fouling somewhere, or the upper pivot of the balance staff is broken.
11 minutes ago, Gaus said:
Hello Tomh207, you're partly right, but then it wil be dial up and dial down I suppose.
I would still look at this first as A) it’s low hanging fruit B) with beat error like this I would think the inherent dynamic differences between DU & DD would possibly be asymmetrically affected.
Tom
You could test this again with just the balance to varify it is something balance assembly related and nothing else. Removing the pallet fork ( make sure the mainspring is unwound ) will isolate the balance for testing, turn the movement over to dial up position and give the balance some air from a puffer to set it in motion . You will see the oscillations from the side , they should last around one minute, or does the balance stop as before ?
  • 4 weeks later...
Hello guys, it took some time te work again on the watches. I promised to let you know what I found out. There was too much sideshake on the escapewheel (not jewelled). I found a donor plate and now it works fine.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
