Hello, everyone! I got my first Jacot tool. It seems to be in the most part complete. The only things that are broken are the lanterns, with just some of the holes stil good, but the rest seems to be good! The Brand is Stainer. I got it for $350. Do you think that’s a good price for the tool. What are your thoughts in general! I
NIce! I don't know what the current market is for these as I bought my brass and SS one a couple of years back and am definitely not an expert, but seems a little steep if the lanterns are damaged. Is it Stainer or Steiner? As long as the lanterns with the groves are good, you can burnish most pivots. the ones with the holes are primarily for polishing tips of pivots, which mostly are for pivots that contact a cap jewel. But again not the expert by any means. Get yourself a small bench vice to hold it and a bow.
20231210_1845502(1).thumb.jpg.ce48218398886c8fa2394b6c5f3fd4f4.jpg20240202_1836012.thumb.jpg.3c9f381fd8681669b1cf9b3a08101bc4.jpg20240202_1835493.thumb.jpg.1306d7dad668fdc05d9d340cab319aaf.jpg
Yours is a nice set too! I actually bought two. I ordered one from the Czech Republic about a month ago, but I haven’t got it yet. It seems like there is a problem with the postage because I was supposed to get it January 14th. Then I saw this one that somebody else was selling on eBay and I went ahead and bought it because I needed it. Once I get the other one I will see if I will sell it since two are probably not necessary. I may have misspelled the name. I think is Steiner. I guess the other one I am waiting for is very similar to yours.
here it’s a picture of it:
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
