Greetings from Memphis,
Just finished my watch with ETA 2834 Top Grade movement. The watch is running slow, and on close examination, the seconds per day rate varies from -10 to -12 with the second hand at the twelve  o’clock position to about -20 to -23 with the second hand at the six o’clock position.  A variation of about 10 seconds each revolution . I Have worked with three ETA 2824 movements and their accuracy has always been -+1 second with a beat error slightly about zero.
Any ideas on why the rate would vary this amount?
As always thanks for your comments and a Happy New Year to all, Dave
If you've got variations occurring periodically, you can usually trace it to an issue with the wheel that rotates at that rate. This is slightly complicated in that you have a center seconds hand, so that adds a piece or two to look into. The long thin shaft of that seconds hand is where I'd start in your shoes.
Thanks Specter,
Thats what I was thinking. I’ll pull the movement and take a look. Second hand hub may be out of round and rubbing some where. I can pull the hands and check the regulation to see if the problem is in the movement.
Dave
Thanks Specter,
Dave
Removed the hands and regulated movement to zero seconds per day. I’ll see if I can find where the hands are hanging up.
Dave
Check that the seconds wheel is flat, and not too much endshake, allowing it to touch a bridge or another wheel. The upper jewel can get pushed out a bit if hands have been pushed on too hard.
Edited by mikepilk
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
