ETA 2512-1 strange issue. Going from perfect to snowstorm
Hello.
I’ve got this ETA 2512-1 that i just gave a service. It was running fine (see timegrapher) - maybe not as high amplitude as I wanted, but didn’t change mainspring.
After I cased the movement it got completely snowstorm and could barely get a reading. I took the movement out and it was still snowstorm. I could regulate it back, but now it’s running very weak and snowstorm…
My plan was to redo the whole thing, and inspect everything under the microscope
It had some corrosion, before service but maybe I didn’t got it all out..
EDIT:
I did demagnetized the movement after it did the strange reading.
Any suggestions?
UPDATE:
After sitting and running for 24 hours I get this reading on the timegrapher (without regulation, that can easy be regulated to be perfect)
-12 seconds
277 amplitude
2.6ms beat error
Is that normal?
(photo of movement is before service)
Edited by apandersP
48 minutes ago, mikepilk said:
Do you have a pic of the 'snowstorm' on the timegrapher ?
Does it occur if you only wind it about half way ?
It seems like we are back to the snowstorm..I’m not sure, but maybe it’s running better in half wind, and that’s why it ran better after 24 hours..
this is now. I can’t get it regulated in.. if I move the regulator more to minus the balance will stop..
Edited by apandersP
Is the hairspring flat and the coils evenly spaced? Are you sure that the hairspring is not hitting the balance arms?
The check I always do is, remove the pallet, give the balance a good blast with a blower, and it should still be moving well after 30s, ideally 45s - 60s.
Just did that check. It stops running after 66 seconds. So that seems to be fine.
But u noticed this. Is that too much play?
Edited by apandersP
  • apandersP changed the title to ETA 2512-1 strange issue. Going from perfect to snowstorm
The side play at the top is a little too much, but the problem is more likely the vertical. It looks like the barrel could be hitting the seconds wheel, mainplate or bridge - especially combined with the side play at the top.
Is it a brass bush at the top?
17 hours ago, apandersP said:
snowstorm.
I'm not sure I would call that a snowstorm it's not good but a snowstorm as a whole bunch a random dots.
Also when diagnosing with your timing machine more than one timing position is nice like dial up, dial down and for a wristwatch crown down would work. Because often times things will not show up in one position only.
then it mainsprings interesting in the video because one it's greatly magnified so look much worse and it is. But it doesn't look good and your timing machine looks like a power transmission problem is why it's all over the place.
https://17jewels.info/movements/e/eta/eta-2512-1/
Thank you.
but what would explain this?
after I cleaned and reoiled the balance again. This is the reading after some regulation.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
