How long should winder “hook” be?
I have an old K&D 123 bracelet watch mainspring winder. The arbor is double ended with tiny hooks meant to grab the end of the mainspring. But to me they are not extending far enough…does anyone use such a winder and, if so, can you give me an idea how far the hooks should protrude?
Can you add a picture of handle Glen ? I think have the same ones but made by Star.
Lol my mistake , I thought you started the thread Glen 🤦‍♂️
I'll  start again.....Yokespring can you add a picture of the handle please 😄
What sort of mainspring are you using these with? In their original unmodified form, they work pretty well with old steel wristwatch mainsprings but do not work well at all with more modern alloy mainsprings having smaller holes for the hook.
A photo of what the mainspring looks like when hooked onto the arbor would be good too.
I found a picture online. It seems the hook on that one protudes more than on yours. I also think I see a hole where the arrow points. Does yours have that? If so, you could perhaps drive the hook further out from there.
Edited by caseback
18 hours ago, caseback said:
We're not seeing the back, but perhaps you can press them out a bit further if they're pressed in a hole that's drilled completely through?
The hole for the hook does go all the way through Cees, so yes it is possible to push it further out as you suggest for the OP.
17 hours ago, Yokespring1 said:
Here are pics of handle and spring
I have a couple of sets of these, just a different brand. The hooks do stick out a bit further on mine, there is one that has broken off...needs pushing out and reshaping.  Handy that they wind both ways. They are my goto set when nothing else fits, and if the arbor size works. They come in a set of 3 which gives a range from memory 7ish mm up to around 14mm, though there is a short gap in the range between the medium and large one around the 10-11 mm requirement. There is a bit of a technique involved when using them, the spring has a tendency when the bridle is fed in...to slip around to the next slot and poke back out. Let off on the winder before you feed it in so as to reduce the tension. But apart from those little idiosyncrasies, they're ok.
I have some of these that need a bit of work as well. They are handy – I sometimes use the arbor piece in combination with the barrel/handle from another winder set when it doesn't have quite the right arbor for a good fit to the spring.
If these were 10X as large I'd just take them out to my general workshop and find a punch/vise/hammer combination that works, but this is micro work. What would be the recommended approach using watchmaker-scale tools? Are there purpose-made tiny hardened punches that are thin enough to drive in that small hole?  Or can you generate enough force to slide them out a bit more just by pushing with a rod/wire held in a pin vise?
The pins are too big for pushing out the hook, but with some lathe modifcation and making a different platform to hold the arbor there is no reason this wont do the job.
11 minutes ago, AndyGSi said:
New Timing Chain
Haha not any more , its rare for me to tinker with engines these days, sealed black boxes have me scratching my head. The lock release on one side of the rear doors of my van broke. A new one was over a hundred quid so i thought I'd have a go at repairing it. Just needed a biggish friction pin driving out to seperate the lock to get inside it. Pretty much spot on though Andy 👍it's sold as a chain breaker .
12 minutes ago, Yokespring1 said:
I read that someone was able to drill out the pin with a .5 mm micro bit held in a pin vise…I’m trying that approach which is SLOW X 10. I’ve already broken 1 of 5 bits in the kit. I like the press out idea but the hole is tiny.
The pin might be hardened steel, drilling it out by hand... the hole could end up being quite a bit bigger and not uniform. Size isn't so much of an issue as the hook can be shaped to whatever you want on any size of a new pin.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
