Hello all. I'm working on this Rolex Cellini and when I was removing the retaining ring, this small, strange screw came out. I can see where it goes, but I have no idea what it does. It has a rectangular slot cut in in, and it sits next to the retaining ring, on a post. I haven't disassembled the watch yet, just checking if you guys have seen this. There is only one of these, and it's not a dial retainer.
That is the head that has broken off. normally those screws would be for holding a ring that goes around the movement or they would be for holding the movement in its case.
2 hours ago, AndyGSi said:
So where does it go?
Sorry, it sits on top of this pin
That is what I'm thinking too. It looks like it broke off perfectly, leaving a slot in the screw head.
8 minutes ago, AndyGSi said:
You'd normally have a case clamp in the recess.
This movement is double clamped. It has the clamps above to hold the movement spacer in place, then the above broken screw to hold the movement to the ring. Its set up almost like it can be removed from the front or back for some reason. This movement is only used in the Cellini, so I'm not sure why they need a spacer ring to begin with...
Edited by SwissSeiko
I think it's the fact it's derived from the 1600 which was used in a lot of other Rolex.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
