Just now, AndyGSi said:
Hand or possibly Pinion pullers.
Yeah, I was thinking the same thing about the one on the right. The gnurled round part rotates which moves the 'jaws' together, squeezing the handle drives the center rod down. I'm not sure how that would remove the hands or canon pinion though.
The one on the left is a hand remove although it appears to be slightly broken. The central plunger piece should be attached to the two things protruding just above each of the lever blades at the end of the arms.
To use it you actuate the plunger until the ends of the blades are parallel with the dial and a slight gap between them. You then position the canon pinion in the gap so the blades are between the dial and hands and push down on the whole tool. This forces the arms to rotate and the blade ends to tilt upwards against the hands sliding them off the movement.
They're ok to use but I almost always use standard levers over that type. Excuse the crude drawing but I'm not a great artist!
Thanks, that makes sense.
The one on the right is a roller remover, especially if it has some extra tips stashed in the handle to sit over different sized balance pivots.
Good call, I found another one on ebay. Mine does have extra tips in the handle. I tried pulling out the existing tip but it feels like it is under some kind of spring tension. I pulled on it with a decent amount of force but it feels like I might break it if I pull harder. Do the tips come out by pulling down on them?
BTW, I didn't think to try using Google Lens first, when I just tried it identified both.
Edited by GuyMontag
I'm not sure. I have a few of different roller removers for pocket watches but not this type.
No, they are threaded. Use the handle to grip the tip.
Frank
I believe it is K&D #150. Maybe you can find an instruction sheet. They do tend to be floating around for K&D tools.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
