Hello
I've never worked on a Valjoux 7750 (clone) movement and so I have some issues that have cropped up and am looking for some answers.
1.) As I progressed through the assembly I noticed the balance wheel had stopped  moving just before I was about to put the hands on. So I started to disassemble the components and it wasn't until I disassembled the chronograph module (dial / automatic oscillating weight / calendar works / chronograph) that the balance wheel started up on it's own. My question is what could have prevented the balance from spinning? When the watch was assembled I tried to move the wheel using a probe, however it wouldn't spin up. It wasn't until I continued stripping the movement that the balance started oscillate on it's own.
2.) When manually winding the movement I never get to the point where I couldn't wind it anymore. Is this a function of how the mainspring operates in an automatic movement or should I further strip the movement and check the mainspring to see its broken?
Thanks in advance for any help that can be provided.
1. I would suspect that when you add one of the chrono parts something binds. I don’t believe the 7750 is a module based chronograph, maybe terminology here?
2. In an automatic movement you can wind it forever as the spring is designed to have a controlled slip on the barrel wall with the appropriate braking grease.
Tom
If the movement won't run even with the chronograph disengaged, then the first place I'd look is make sure you have the oscillating pinion (shown below on the right) the right way around. It will fit either way, but I believe the one side is just a hair taller and if put in incorrectly will bind.
Thanks for the feed back. I will review Marks video regarding the oscillating pinion and see if I installed it upside down. Thank you for confirming the operation of the mainspring. Now I know I don't need to strip the movement completely down.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
