Any suggestions as to cause? I've cleaned and lubricated the movement and it runs ok with a reasonable amplitude. But it's gaining 15 minutes a day, both in real life and in the time grapher. That's with the regulator arm as slow as possible.
I've demagnetised. I've had the balance wheel off to properly inspect the spring and it looks true to me. What else is there?
It sounds to me like the balance is too light because the poise screws have been shaved, reducing the total weight of the balance, thus speeding it up.
I find this to be the case in some vintage watches and the index over to the slow side to try and compensate for the light balance is a dead give away.
If this is the case, I would start by statically poising the balance and add some timing washers for the amount of time you are gaining, then fit the balance into the serviced movement and dynamically poise the balance now, remembering that at 220 degrees of amplitude any poise issues will not be evident. I find it best to poise at a low amplitude, as this shows the error more apparently, but that's just the way I like to do it. You could be there for some time when it comes to dynamically poising!
Let us know how you do?
Looking at @Bonefixer original post it looks more likely that some screws have been completely removed?
That's going to be an interesting project if that is the case, although I would expect it to be gaining more time with a couple of poise screws missing.
Sometimes there are holes for screws but they're not there as they weren't needed for the poise. I'm not totally sure why there would be a hole for no poise screw to be honest
@Bonefixer Be interesting to see a photo of it out of the movement to confirm if this is the case.
Willco. Give me a few minutes
Thanks for your replies. There are no extra holes for poising screws.
One thing I did think - could the spring itself have been shortened? Off the cock it's perfectly in shape, but when the stud is fixed in place there seems a bit of a stretch on it to the fulcrum pin, as though it could do with an extra half circle of spring. This would certainly explain it running fast, but no idea why this would have been done, except maybe a bodged repair?
Edited by Bonefixer
Perhaps someone switched the hairspring from another balance. I can see two clearly filed screws at about 3:30 and 5:00, and two that appear to have been unscrewed a bit in hopes of slowing it down at 1:00 and 7:00. The filed screws may be original, not a great practice but have seen it where it had to be "factory".
That is a fair bit of hairspring sticking out the stud, don't usually see that aside from really cheap pin levers/cylinder watches. Maybe they got mixed up and shortened the spring in an attempt to slow it down? You can definitely unseat the pin and slide a couple mms out to increase the length (don't forget to adjust the beat). Make sure all the balance screws are tight before doing any adjustments.
Edited by nickelsilver
Suffering brain fog at the moment but shouldn't the spring have a set before it enters the stud?
Also does look to have an excessive amount from the stud and isn't central.
There were a number of mid-century mid-grade calibers that had just the slightest offset to the terminal curve to reach the stud, and no real bend or anything at the stud.
I've looked at quite a few springs for the 48 and they all appear to have the offset.
Edited by AndyGSi
I've re pinned a balance spring into a stud once before on a junk movement, and probably not very well. Could anyone guide me as to what to do? Do I leave the stud in place, push the pin out, pull the hairspring through a bit and then put the pin back in? I realise I'll then have to take the wheel off and adjust the collet to centre the impulse jewel.
Is that about it?
With all these shortened weight screws on one side, you can bet the staff was once changed by a specialist (hello punchers!).
In the course of the needed work you should do a static poise test, too.
Frank
Working on a 48 now: just a slight offset.20250201_185457.thumb.jpg.2b9804491b43a3781b58185397347567.jpg
You could move the stud to this position (looks like the original one) and see what happens..Screenshot_20250201_185532_Chrome.thumb.jpg.167c8aa718d0ac7b8bc152ee06c5190b.jpg
Is that about it?
Sounds like a plan.
Edited by caseback
Yes, the first thing to do is extend the hairspring as much as possible from the stud, then show picture to see if it needs correction in order to be centered and parallel to the cock.
Often when the watch has lo amplitude and poor performance, it looses time. Then a clever repairman appears that will shorten the spring in order to increase the rate. Let's hope this is the case.
Thanks everyone. Progress update. I've repinned the hairspring to the stud (lost the brass pin - no idea how or where it went - but had some replacements) and rotated the collet by the same amount.
It now can run fast or slow depending on the position of the regulator, and in the middle it's keeping good time. Beat error is 4ms so I'll need to adjust the collet a bit more, but apart from that I think it's solved.
  • Like 6
Sorry, forgot to tell you that sticking a small blob of rodico on it prevents it pinging away 🙂
It just evaporated I think. I managed to ease it out, and it was half in position, I could gently slide the spring and it was still there. It didn't ping, it just fell out and went through the hole in my little hexagonal staking block. Then vanished.
I'm quite experienced at losing click springs, pinging tiny screws etc, but this one I've just no idea where it went. I was being really careful and nothing happened. It was just gone.
It's probably still stuck in the staking block.
I just got a funny picture in my imagination of a pile of tapered pins under your bench Nev @nevenbekriev, then I remembered how big stud pins are, the whole pile of many years of losses probably only amounts to 2mm cubed. 😂
Tom
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
