Hamilton Valjoux 7732 dial up fault
Aloha. Looking forward help with my nearly finished project. Watch is running great dial down… cased and checked dial up… garbage. Low amplitude, running 2 minutes fast, beat error is like 7ms. Also there is a noise when dial up like maybe the hairspring rubbing? Tinny noise in time with the escapement beat. Maybe I need a new balance staff? There is no way to adjust the endshake on the balance is there? Thought that might be the issue. I’m attaching time-grapher pics. Thanks in advance for any ideas.
Hey @WatchHor
You'll need to send us pics of the movement and the balance (especially from the side while it is running dial up, to see if the hairspring is rubbing somewhere).
Hard to say from timegrapher alone, but it sounded plausible that the hairspring is rubbing.
Cheers
31 minutes ago, Knebo said:
Hey @WatchHor
Cheers
Yes I kind of think the hairspring is rubbing on the hour wheel (second wheel?). When I got the watch it was hitting the wheel and causing it to barely run at all. I moved the hairspring stud down a few just a touch and it it solved the issue. It doesn’t seem to foul when dial up just looking at it but the noise is what tipped me off that it might be rubbing. Of course it could be rubbing on the balance itself.. in short it looks normal.. nothing wrong that you could see in pictures. But the tinny noise and grapher makes me think there’s too much end shake? Causing the balance to drop just a bit dial up and either push the balance against the hairspring or the hairspring against the hour wheel. Is there a what to adjust end shake in the balance?
This perspective doesn't really help. It would have to be properly from the side, like this:
Need to see if the hairspring is flat and parallel to the balance wheel.
Moving down the stud will often give the hairspring a tilt (because the collet on the balance staff and the regulator pins/shoe will stay the same).
Hmm.. seems flat to me. To get that angle I’ll need to get it back out of the case. It doesn’t function at all with the stud in almost any other position. A little bit higher and the spring knocks against the wheel and any lower and the stud fouls on the spokes of the balance completely stopping it.
I guess you'd need to get it out of the case anyway to fix and issue. Clearly, it's not good as it is.
One thing you could check before, though, is the endshake of the centre wheel. Maybe, when installing the chronograph seconds hand (and you, or a previous repairer, didn't support the jewel/bridge), it may have moved the jewel and increased endshake to an extent that now it goes up/down and fowls the balance/hairspring.
Seems like too much endshake on the balance.. are these shock setting plates adjustable? It looks as if there is a notch to pry them free. I don’t think they are threaded though I could be wrong… I have a staking set but no jewel setting tool which I think would be required for the micro-adjustments that would be required. Going to a professional on Tuesday if I can’t get this figured out by then. Attached pictures of the balance cock top and bottom showing the plate
Just an update for anyone following... I solved the issue after watching a video explaining how to hack/bodge balance endshake. In the video a balance was too tight causing loss of amplitude. To "adjust" a small gouge was made with a screwdriver on the plate resulting in a tiny bump on the plate north of the cock screw tilting the balance up slightly... so in my case I made the gouge south of the cock screw which gave me the desired result tilting the balance cock slightly down. Timing is still +/- 15sec depending on position but there is no rubbing noise. Decent result for a 60 year old watch 👍
That's totally acceptable!
There was a discussion about this recently if this is a bodge or acceptable. I'll say: problem solved, well done!
Gorgeous watch, by the way!!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
