Hello again, people.
Charity shop asked me to get this little (20mm dia movement) pendant watch working. Having done so I found it stops when it is cased. I can't see any obvious reason for this (the flat spot on the rhs of the caseback is the inner part of the indent designed to allow it to be 'popped' off). I'd appreciate suggestions as to what to look for & address to fix the issue.
3 hours ago, AndyGSi said:
First thing would be to check the hands against the lens.
Is there no holding ring for the movement?
Thanks, Andy: the hands seem fine - but I'll check if the second's hub  could be pressed down any. There is no holding ring present nor does there look to be room for one (see photo). It seems it's only when the caseback is fitted that there's a problem.
On 2/10/2025 at 3:42 PM, AndyGSi said:
The balance looks like it's very close to the back.
Is these a gasket on the back?
Yes it is but it doesn't seem so close as to touch the caseback edge and there isn't a gasket. I'm currently looking to see if I can find a screw with a thinner head than that currently securing the escape lever bridge.
1 hour ago, AndyGSi said:
I can't see how pressure on the screw would stop the movement and it doesn't look any different to this.
I've established that pressure on the escape lever bridge screw does indeed stop the movement.
22 minutes ago, Neverenoughwatches said:
How accurately can you measure how much of the movement stands above the case rim and compare that to the recess in the caseback.
Thanks, I'll try that comparison. At the moment I'm seeing if there's an orientation of the caseback that works as it is embossed (see initial photo).
Thank you for your help, Folks. I managed to solve the problem by attaching the caseback at successive positions 'around the clock' until, thankfully, finding an orientation which allowed the watch to run ok.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
