This continues to behave - fitted the correct dial spacer and movement holder today as well. I've actually ran it through every date without issue now, though am also checking it keeps running fine with normal use.
On 2/14/2025 at 11:32 PM, HectorLooi said:
use a synthetic grease like 9504. It gives a noticeably sharper snap when the date changes
+1 here.
Tiny amounts on just a few teeth.
55 minutes ago, Knebo said:
+1 here.
Alex Hamilton had an interesting idea, a piece of pegwood with some grease rubbed into it then ran the greased edge all around the inside of the ring.
I did that on a handful of movements and, at least in my hands, I was getting too much grease on the teeth. I was probably charging the plastic stick I was using with too much grease, but I ended up going back to doing it manually as I feel I have more control.
I think the idea is to rub the grease into the wood so that only a wet surface is visible but no actual grease. That was my understanding of it anyway.
That makes sense
2 minutes ago, GuyMontag said:
Yeah, I may have to give that method a try again as it's a bit of a pain when the movement doesn't have a quickset date.
Indeed!
Well I've been around all of the dates now without any issues, so I'm guessing the clean and refit did the trick, with whatever else I did not breaking it!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
