Please assist in helping me source anybody that sells cylinder balance staffs for baby French Carriage clocks. I require such for my clients clock. They are seemingly rare.
You do know cylinders come in three parts each end called a plug and the centerpiece. With the right cylinder stake you can tap the end plugs out.
Edited by oldhippy
like so...
There used to be assortments of cylinders and plugs (they're called "tampons"). I suppose back in the day, with time not being important, one could sort through and find something that might work, but the fit of the tampon to the cylinder is such a precision fit, that I imagine one would always have to do some lathe work to get it right.
I have always simply turned up a new plug, or drilled the tampon/plug in the cylinder and fitted a new pivot, which avoids having to get the right fit on the tampon and risk cracking the cylinder.
The problem is when the cylinder is broken in the middle.
And I know this is the case, as this question was asked in another forum.
OP, You need to measure very precise the diameter of the cylinder, the entire height needed and the height of the mouth from the bottom pivot tip in order to search for proper one. But, big cylinders as for platforms are so rare that I don't believe it is possible to source. I have made such cylinders for platforms several times, this is a specific work.
  • Similar Content
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
