shallac remains a bit soft...
Hi all,
So I've recently, for the first time, refitted a pallet stone with shellac. I used this one from Cousins: https://www.cousinsuk.com/product/shellac-stick-clear?code=S1522
I think it went well. I heated it on a brass plate and it gently melted (no bubbles from over-heating). Also no alcohol exposure.
Now, about week later, I notice that the shellac is a little bit soft. I can make little dents into the otherwise round-clear shape of the shellac with an oiler.
Sorry, no photos this time...
Any ideas what's going on?
Shellac is kind of soft. Some more than others, some is really brittle, some melts at a lower temp, some a higher temp. We had stuff in school that was called shellac but was a muddy light brown color; worked great but didn't look "normal". I think it was more like sealing wax.
My last employer had a bunch of really old flake shellac that was great, and normal looking too 😄. As shellac gets older, it's "meltability" often goes down; this stuff was like 40 years old and fine.
I wouldn't worry about it.
That kind of shellac is more for mounting jewels to dop sticks for shaping and polishing.
The shellac for mounting pallets jewels are in flakes.
https://www.cousinsuk.com/product/shellac-flakes
You can either break off small pieces and place them on the pallet jewels and warm it over a flame or melt a small piece on your pallet warmer and dip the end of a toothpick into it and draw out a whisker of shellac. The whisker can be dabbed onto the heated jewels like solder wire.
I find that the clear shellac has a sharper, more defined melting point. The opaque, cloudy type contain oils and waxes which affects the melting point and hardness.
Thanks so much already for your responses @nickelsilver @HectorLooi
The stick itself is really brittle. I broke of little flakes and they are proper hard. But after melting it onto the fork, it seems softer.
The description on the Cousins website said that it's also for pallet stones, so I assumed it was fine. I basically made my own flakes from it. When pressed with a hard object, it cracked, looking almost like glass. So the heating definitely changed its hardness. I wonder if it'll harden over a longer time... .
The stick I have actually looks "better" than the picture on the website. It's yellow-ish, but actually rather clear when broken down in small flakes.
My preferred material for fixing pallet stones now is UV cured resin. After adjusting and testing the locking depth of the stones, just apply 2 tiny drops of the resin and shine a UV light on it for 20 seconds and it sets rock hard.
After that, the pallet fork can be washed in IPA to remove any traces of the uncured resin. If you want to remove the pallet stones, just soak it in acetone for a couple of minutes to soften the resin.
Shellac comes from beetle secretions so is organic and will vary. Flakes are the best for us and have a longer shelf life. Test before use by melting a spot away onto a metal plate and examine the hardness the next day. The colour is mainly due to wax content - more wax - darker colour and it takes longer to harden off. This is great for French Polishing where you need some lubrication as the finish is rubbed onto to the wood. We need the harder De-Waxed blonde style which is also great for grain filling open pored woods before top coating. Worth doing for the lovely smell. Picture here of the last project from a previous mad hobby. 64 coats of shellac. Love the idea of using UV cement - will steal that trick. Modern guitars are finished in a UV curing polyurethane paint - takes 30 seconds so very useful.
I wonder how the next watchmaker wanting to adjust or change the jewel, will judge that ? Cursing?
Frank
  • Haha 3
Fellow luthier here (also been a long time). Shellac/French polish is my favorite finish. I even finish the handles on all of my tools with it (chisels need to be redone from time to time for obvious reasons). I actually prefer the garnet variety though. Adds a natural depth of color that is really difficult to beat, especially on walnut. I only break out the blonde for very special woods that don't benefit from the beautiful deep red color.
Another Luthier. Another poorly paid activity with loads of expensive tools. The fiddle was for my grandson and shellac gives a lovely lustre and is easily repaired. UV cement should be ok to dissolve once you’ve figured out what you’re dealing with.  Warning sticker? 🥹The UV paint on modern guitars is dreadful to remove - nothing legal dissolves it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
