Help with Seth Thomas mantel clock
tyl
Well, my fault.  That is certainly bad news and I give up.
Many thanks for all the help.  If I have learned anything, it is that i actually enjoy working on these clocks and wish I was better at it.
Thanks again.
Thanks again.
Where in the world are you?
Atlanta, GA, USA
Just as a point of interest, how should I have released tension on the mainspring?  I just guessed and took a chance that by removing the outer shell I would find a way to do the release.  Unfortunately that was the wrong approach.  Should have asked earlier.
Edited by tyl
Atlanta, GA, USA
I thought if you were UK then I'd have a look for you.
It's not as easy on these compared to a key wind but you needed to turn as if you were
winding it to loosen the click then hold out of the way while you let the power down.
Ideally it's a 2 person job so you've got better control of the wing while someone else holds the click which I think would be this.
Interesting.  Need to do a search.  So heat the tooth on my electric stove burner gently and try to bend it back?  Or could I put it in a vise, heat it with a butane fireplace lighter, and try same.
Interesting.
Thx.
Edited by tyl
Hi well Andy, what has Tyler got to loose so better to try even if it fails. Tyl if you still like clocks after this, and no reason why not as I would think most of us have done the same . Forgetting to power down or thought you had but did not back check so take heart from that fact we have all been there believe me. That little clock although simple to most of us not so for a begginer due to its construction. Next time get a time only clock between two plates. Post us pictures and we will start again. Don’t loo feel too bad it’s all experience.  All the best WW.
Hi tyl. Best tool would be a small butane torch. And roll each tooth back with a small tube or screwdriver blade just be careful.
10 minutes ago, RichardHarris123 said:
I have an idea for a let down tool for this type of clock. I'll post one of my superb drawings tomorrow.
Make sure you Patent it !!!!!!!
Interesting.
Thx.
Some may bend without heat but you should have a feel for it once you start.
If you do need heat then as @watchweasol said a small torch would be best.
All my clock stuff is in storage at work along with my tubes but I'll dig something out tomorrow and post some photos.
If nothing else you'll get practice if the next clock has the odd crooked tooth.
7 hours ago, tyl said:
Excellent.  Thx.
Well a tooth broke off so I guess I am toast.
It’s possibly a long term learning opportunity. Put it aside for now and research the techniques to replace a toot/block of teach and tackle it once you maybe have a go with some scrap stuff afterwards.
Tom
You wouldn't be able to sort those teeth out for starters I can see a crack in one and the others will be too week to stand the force of the spring.
There is no tool to let this movement down. You need to have the key attached and poke a strong thin wire down where the click is and with your hand trying to wind it will release the click the wire comes into play by keeping the click away and slowly let the spring unwind.
56 minutes ago, RichardHarris123 said:
My idea for a let down tool, is to cut slots in so wood or metal if you can machine it, to accommodate the lugs on the winder and a whole in the centre to accommodate the knob. Turn down the other end to a comfortable hand size.
Patent Pending
[...] Turn down the other end to a comfortable hand size
Or just a square shaft that you can connect with an existing let-down tool.  To be honest, I'd only bother if I was servicing ones of this type regularly.  It's a simple enough task to do it manually as a one-off.  As OH says, a piece of stiff wire would be enough.  I do prefer to use the let-down tools rather than a winder;  They have less tendency to whip your fingers off if you slip 🙂
Edited by MikeEll
5 hours ago, RichardHarris123 said:
I don't know if it would work, I'm waiting for someone with more experience than me to give their opinion.
If it would work, it's my gift to horology.
It still wont work because you need to be able to release the click.
Success.  I just received the clock from across the pond where it was expertly repaired by forum member known as MikeEll.
After I so disastrously mangled the gears by failing to release the mainspring tension, this one was a goner.  With forum help I attempted to straighten out several gear teeth only completely to break off a tooth.
Mike came to my aid and we have been working together for about two months.
The clock is absolutely beautiful and will be passed down to my grandson as coming finally from his great, great, great uncle.  But now I intend to keep it a lot longer than originally planned.
Thank you so much Mike for your expert work and willingness to help me out.
Pic attached.  (I love this forum.)
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
