Help with Seth Thomas mantel clock
tyl
Mike - I just realized that the forum members including myself might be interested to know how you let down the mainspring.  Reading back through these posts it looks like no one exactly knew how to do it.
Thx.
Thx.
Of course.  OH did comment what needed to be done using a stiff wire or similar. The following procedure needed to be done while the half plate was in position, as this is what prevents the click components falling apart and self-destructing the clock. Every clock with a mainspring will have some sort of ‘click’ arrangement to prevent the spring from simply unwinding as you wind it.  On your clock there are two mainspring barrels allowing it to run for 8 days or so with relatively small mainsprings.  The barrel ratchet wheels both engage with a shared intermediate gear attached to the winder.  You can see the click in the picture (see red), which is held between the main plate and half-plate (removed in this pic), and is itself spring loaded from the other side of the main plate to keep its teeth engaged.  To release the main spring power you need to securely hold the movement as you’ll need both hands free, or find a helper.  Fit the winder and apply just enough wind to lift the click (see red arrow), then insert a slim screwdriver or stiff wire to hold the click away from the ratchet wheels (see blue line).  This is the risky part where you mustn’t let the winder go.  Gently unwind as much as you are able to do safely,  probably only a single turn of the winder key if you are lucky, then remove the wire allowing the click to re-engage.  Rinse and repeat until no more power remains.
I discovered quite a few issues that needed to be sorted.  Obviously the wheel had been destroyed when the click let go, but there were also damaged teeth on both barrels.  I simply replaced these from a donor movement we were lucky to find.  The center wheel arbour was bent, and most of the brass bushings had cracked and come loose, along with the cracked center wheel pinion/gear that had the crack in the earlier pictures.  I think this is a design flaw in the clock, they really should have used steel for those parts.  I used the replacement center wheel with good bushings, then for the pinion/gear I opened up the crack with a fine file and soft-soldered it up.  Finally I closed up the central hole of the gear with a staking set to get a good friction fit on the shaft.
The other problem was I think there was a missing dial washer, which allowed the hour wheel to lift out of position, preventing the hour hand from turning.  I replaced that with a domed washer.  All that and a thorough clean and service, and she’s up and running.
I’ll upload more pictures when home at the weekend, the internet connection is crap in the hotel I’m in.
Edited by MikeEll
A few more pics….
The steel rule shows the position of the dial when fitted to the clock case.  You can see the dial washer I’ve added. Without that you can see how the hour wheel could move excessively allowing its teeth to disengage.  That’s one of the reasons the hour hand wouldn’t turn.
The cracked gear from the minute wheel, opened up with a file and soldered…
the central bore was closed up a little with a staking set to give it a good friction fit.
Stripped, ready to clean.
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
