Omega lady help
4 minutes ago, AndyGSi said:
Så kollade du att den nya rörelsen fungerade när du fick den?
I changed som parts between two of the same movements so not sure. But i have measured the coil and electric with multimeter and it seems ok. so why aint the rotor going since it is in correct seat?
You need to find out if the cmos is pulsing a regular current  to the coil. This can be anything from 1-20 seconds, quartz without second hands have a longer pulse time. One caught me out some years ago that I thought had a bad chip, it was on the long side of pulse rate.
The circuit board and cmos can be tested in isolation,  just needs a power supply and something to monitor the pulses.
  • 4 weeks later...
On 2025-02-27 at 17:49, Neverenoughwatches said:
Du måste ta reda på om cmos pulserar en vanlig ström till spolen. Detta kan vara allt från 1-20 sekunder, kvarts utan sekundvisare har längre pulstid. En fångade mig för några år sedan som jag trodde hade ett dåligt chip, det var på långsidan av pulsen.
Kretskortet och cmos kan testas isolerat, behöver bara en strömförsörjning och något för att övervaka pulserna.
Hi again. I ordered a new movement from cousin uk but it stops exactly after 1 hour after setting time with my original hands and crown. If setting time again it runs 1 hour then stops.
What can be issue?
What can be issue?
First thought would be the hands are clashing.
Can you post a photo from the side with it out of the case.
Edit
What movement have you got from Cousins?
Edited by AndyGSi
15 hours ago, AndyGSi said:
Första tanken skulle vara att händerna krockar.
Kan du lägga upp en bild från sidan med den ur fodralet.
Redigera
Vilken rörelse har du fått från Cousins?
You were right. Took of hands and took it on again and this time it works perfectly. Thanks for all help! Case closed
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
