Omega lady help
4 minutes ago, AndyGSi said:
Så kollade du att den nya rörelsen fungerade när du fick den?
I changed som parts between two of the same movements so not sure. But i have measured the coil and electric with multimeter and it seems ok. so why aint the rotor going since it is in correct seat?
You need to find out if the cmos is pulsing a regular current  to the coil. This can be anything from 1-20 seconds, quartz without second hands have a longer pulse time. One caught me out some years ago that I thought had a bad chip, it was on the long side of pulse rate.
The circuit board and cmos can be tested in isolation,  just needs a power supply and something to monitor the pulses.
  • 4 weeks later...
On 2025-02-27 at 17:49, Neverenoughwatches said:
Du måste ta reda på om cmos pulserar en vanlig ström till spolen. Detta kan vara allt från 1-20 sekunder, kvarts utan sekundvisare har längre pulstid. En fångade mig för några år sedan som jag trodde hade ett dåligt chip, det var på långsidan av pulsen.
Kretskortet och cmos kan testas isolerat, behöver bara en strömförsörjning och något för att övervaka pulserna.
Hi again. I ordered a new movement from cousin uk but it stops exactly after 1 hour after setting time with my original hands and crown. If setting time again it runs 1 hour then stops.
What can be issue?
What can be issue?
First thought would be the hands are clashing.
Can you post a photo from the side with it out of the case.
Edit
What movement have you got from Cousins?
Edited by AndyGSi
15 hours ago, AndyGSi said:
Första tanken skulle vara att händerna krockar.
Kan du lägga upp en bild från sidan med den ur fodralet.
Redigera
Vilken rörelse har du fått från Cousins?
You were right. Took of hands and took it on again and this time it works perfectly. Thanks for all help! Case closed
